How do I evaluate if a web service is running?
7133
22
05-11-2015 08:02 AM
ChrisSergent
Regular Contributor III
Before my code runs, I would like to evaluate if a web service is running. How would I do that in JavaScript?
OwenEarley
Occasional Contributor III
The above approach should work - see this live example: ESRI Service Test
Note that I also add your server in the esri.config so you don't get other CORS errors:
esri.config.defaults.io.corsEnabledServers.push("maps.decaturil.gov");
ChrisSergent
I still get the 500, but simply as an error. It's not writing to the console.
ChrisSergent
To evaluate if a layer if any web services are not running, you would enter the following code:
app.map.on("layer-add-result", function (evt) {
            console.log(evt);
            var testValue = evt.layer.valueOf();
            if (testValue._div == null) {
                /* Page Redirect */
                window.location.assign("http://www.w3schools.com")
You may not need app for your application.
