I have a GraphicLayer that I build using a QueryTask. One of the attributes is a date field. When the InfoWindow for this layer is rendered, it displays the date in Epoch or Unix format, IE, -297512519. I've tried various solutions for formatting the date in the InfoTemplate. Here are a couple of them:
${PRINT_DATE:DateFormat(selector:'date')}
${PRINT_DATE:DateFormat(datePattern:'MM/dd/yyyy.', selector:'date')}
With a custom function. This works in formatting my DataGrid. I've tried to embed this inline into the InfoTemplate
${PRINT_DATE:formatDate}
function formatDate(datum){
if (datum){
var d = new Date(datum);
return dojo.date.format(d, {
selector:'date',
datePattern: 'MM/dd/yyyy'
return;
Any suggestions?
Craig
Hi Robert,
Thanks so much for replying. I actually had tried your proposed solution previously without luck. I did find a solution though. I found this old thread and based my solution on it, InfoWindow formatting I also used code from this site, Epoch Date Conversion - JSFiddle.
In case anyone else runs into a similar issue, here's what I did.
var docInfoTemplate = new InfoTemplate(); docInfoTemplate.setTitle(generateInfoTitle); docInfoTemplate.setContent(generateInfoContent); //creates string for info tag function generateInfoContent(graphic){ var formatString = "<b>Bar Code:</b>" + graphic.attributes.BARCODE + "<br/><b>File Number</b>: " + graphic.attributes.FILENUMBER + "<br/><b>Date: </b>" + formatDateInfoWindow(graphic.attributes.PRINT_DATE) + "<br/><b>System</b>: " + graphic.attributes.SYSREF; return formatString; } function generateInfoTitle(graphic){ var formatString = "<b>File Number</b>: " + graphic.attributes.FILENUMBER; function formatDateInfoWindow(value){ formattedValue = ""; if(value){ var dateVal = "/Date("+ value + ")/"; var date = new Date(parseFloat(dateVal.substr(6))); formattedValue = date.getMonth() + "/" + date.getDate() + "/" + date.getFullYear(); } return formattedValue; } return formatString; }
Craig
Craig,
Here is a sample that uses a query to populate a GL and sets the GLs infotemplate to use a date format:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <title>Date Format</title> <link rel="stylesheet" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css" /> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #mapDiv{ padding:0; } </style> <script src="https://js.arcgis.com/3.17/"></script> <script> var map, gl; require([ "esri/map", "esri/layers/FeatureLayer", "esri/InfoTemplate", "dojo/parser", "esri/tasks/query", "esri/tasks/QueryTask", "esri/layers/GraphicsLayer", "esri/graphic", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/Color", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, FeatureLayer, InfoTemplate, parser, Query, QueryTask, GraphicsLayer, Graphic, SimpleMarkerSymbol, SimpleLineSymbol, Color ) { parser.parse(); map = new Map("mapDiv", { basemap: "hybrid", center: [69.698, 26.057], zoom: 6 }); map.infoWindow.resize(250,95); map.on("load", mapLoaded); function mapLoaded() { gl = new GraphicsLayer(); gl.setInfoTemplate(new InfoTemplate("${Name}","Magnitude ${Magnitude:NumberFormat(round:2)} earthquake occurred on ${Date_:DateFormat(datePattern:'MMMM d, yyyy.', selector:'date')}")) map.addLayers([gl]); var queryTask = new QueryTask("https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/Since_1970/MapServer/0"); var query = new Query(); query.returnGeometry = true; query.outFields = ["*"]; query.where = "Magnitude > 6"; queryTask.execute(query, showResults, showError); } function showError (err) { console.error(err); } function showResults (results) { var resultItems = []; var resultCount = results.features.length; var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255,0,0]), 1), new Color([0,255,0,0.50])); for (var i = 0; i < resultCount; i++) { var gra = new Graphic(results.features.toJson()); gra.setSymbol(symbol); gl.add(gra); } } }); </script> </head> <body class="claro" style="font-size: small; font-family: Arial Unicode MS,Arial,sans-serif;"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="mapDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
Hi Robert,
Craig
Craig,
Strange that the full sample I sent you works fine but you could not get it o work. Either way glad you found a solution.
Don't forget to mark this thread as answered by clicking the "Correct Answer" link on the thread that answered your question even if it was your own.
