Hoover Javascript API
731
7
04-26-2012 02:34 PM
akashmagoon
I added onto a sample.
The circle represent pushpin and when you click on it, it will open a info window.
How can i make the info window popup by hovering.
I tried the Mouseover call but it didnt work.
Heres my current code.. Please edit it. Thanks in advance.
<!doctype html>
<html lang="en">
  <head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title></title>
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map{ margin: 0; padding: 0; }
    </style>
    <script>var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
    <script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      var map;
      function init() {
        var initExtent = new esri.geometry.Extent({"xmin":-14052134,"ymin":5562249,"xmax":-13179529,"ymax":5897349,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map",{extent:initExtent});
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
        dojo.connect(map, "onMouseOver", function() {
          dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
          var points = {
            "points": [[-122.63,45.51],[-122.56,45.51],[-122.56,45.55],[-122.62,45.00],[-122.59,45.53]],
            "spatialReference": ({ "wkid": 4326 })
          var mp = new esri.geometry.Multipoint(points);
          var wm_mp = esri.geometry.geographicToWebMercator(mp);
          var sms = new esri.symbol.SimpleMarkerSymbol();
          var infoTemplate = new esri.InfoTemplate("Bob <br> Lives in the USA", "");
          var graphic = new esri.Graphic(wm_mp, sms, '', infoTemplate);
          map.graphics.add(graphic);
      dojo.ready(init);
    </script>
  </head>
  <body class="tundra">
    <div data-dojo-type="dijit.layout.BorderContainer"
         data-dojo-props="design:'headline',gutters:false"
         style="width: 100%; height: 100%; margin: 0;">
      <div id="map"
           data-dojo-type="dijit.layout.ContentPane"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
ShreyasVakil
Occasional Contributor II
I have made some changes to your code to enable hover on the points. Please see if this works for you.
<!doctype html>
<html lang="en">
    <head>
        <title></title>
        <style>
            html, body {
                height: 100%;
                width: 100%;
                margin: 0;
                padding: 0;
            #map {
                margin: 0;
                padding: 0;
        </style>
        <script>
            var dojoConfig = {
                parseOnLoad: true
        </script>
        <script>
   dojo.require("esri.dijit.InfoWindow");
            var map;
            function init() {
                    "xmin": -14052134,
                    "ymin": 5562249,
                    "xmax": -13179529,
                    "ymax": 5897349,
                    "spatialReference": {
                        "wkid": 102100
                map = new esri.Map("map", {
                    extent: initExtent
                dojo.connect(map, "onLoad", initfunctionality);
     function initfunctionality() {
                    var points = {
                        "points": [
                            [-122.63, 45.51],
                            [-122.56, 45.51],
                            [-122.56, 45.55],
                            [-122.62, 45.00],
                            [-122.59, 45.53]
                            "wkid": 4326
                    var sms = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE).setColor(new dojo.Color([255,0,0,0.5]));
     var graphic = new esri.Graphic(wm_mp, sms, "",infoTemplate );//, 'onMouseOver', infoTemplate);
     dojo.connect(map.graphics,"onMouseOver",function(evt){
     //map.graphics.clear();  //use the maps graphics layer as the highlight layer
     var content = evt.graphic.getContent();
     map.infoWindow.setContent(content);
     var title = evt.graphic.getTitle();
     map.infoWindow.setTitle(title);
     map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
    dojo.connect(map.graphics, "onMouseOut", function(evt) {
     map.infoWindow.hide();
            dojo.ready(init);
        </script>
    </head>
        <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false"
            <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
        </div>
    </body>
</html>
Thanks!
StephenLead
Regular Contributor III
Your code has the onMouseOver event listening to the Map itself - you need to listen to the graphics:
function init() {
 dojo.connect(map, "onLoad", function() {
  var points = {
  var infoTemplate = new esri.InfoTemplate("Bob","Lives in the USA");
  dojo.connect(map.graphics, "onMouseOver", function(evt) {
                  var g = evt.graphic;
                  map.infoWindow.setContent(g.getContent());
                  map.infoWindow.setTitle(g.getTitle());
               dojo.connect(map.graphics, "onMouseOut", function() {map.infoWindow.hide();} );
Steve
akashmagoon
Thanks Vakil Ji and Steven. Thanks for the quick reply
ShreyasVakil
No problem! Let others know if this worked by marking this thread as answered, so that they can follow the same steps and get there issues solved.
akashmagoon
<!doctype html>
<html lang="en">
  <head>
    <title></title>
    <style>
    </style>
    <script>
      var map;
      function init() {
var initExtent = new esri.geometry.Extent({"xmin":-13114922,"ymin":-5500000,"xmax":9292585,"ymax":10351408, "spatialReference":{"wkid":102100}});
  var points = {
   "points": [[-122.63,45.51],[-122.56,45.51],[-122.56,45.55],[-122.62,45.00],[77,19]],
      dojo.ready(init);
    </script>
  </head>
      <div id="map"
      </div>
    </div>
  </body>
</html>
How can i add to this to show the X and Y coordinates in the bottom left like the sample:
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/map/map_xycoords.html
TomJacoby
dojo.connect(map, "onMouseMove", function(evt) {
      var mp = esri.geometry.webMercatorToGeographic(evt.mapPoint);
      dojo.byId("<elementId>").innerHTML = mp.x + ", " + mp.y;
ShreyasVakil
Answer given by Tom is correct.
Refer this code to see how it is implemented in your application:
<!doctype html>
<html lang="en">
    <head>
        <title></title>
        <style>
            html, body {
                height: 100%;
                width: 100%;
                margin: 0;
                padding: 0;
            #map {
                margin: 0;
                padding: 0;
        </style>
        <script>
            var dojoConfig = {
                parseOnLoad: true
        </script>
        <script>
            var map;
            function init() {
                    "xmin": -14052134,
                    "ymin": 5562249,
                    "xmax": -13179529,
                    "ymax": 5897349,
                        "wkid": 102100
                    extent: initExtent
                    dojo.connect(map, "onMouseMove", showCoordinates);
     dojo.connect(map, "onMouseDrag", showCoordinates);
                    var points = {
                        "points": [
                            [-122.63, 45.51],
                            [-122.56, 45.51],
                            [-122.56, 45.55],
                            [-122.62, 45.00],
                            [-122.59, 45.53]
                            "wkid": 4326
   function showCoordinates(evt) {
        //get mapPoint from event
        //The map is in web mercator - modify the map point to display the results in geographic
        //display mouse coordinates
        dojo.byId("info").innerHTML = mp.x + ", " + mp.y;
            dojo.ready(init);
        </script>
    </head>
    <span id="info" style="position:absolute; right:150px; bottom:5px; color:#000; z-index:50;"></span>
   </div>
        </div>
    </body>
</html>
