Hiding a column in a dojox.grid.DataGrid
3282
10-07-2010 12:31 PM
GlenRhea
I'm trying to hide a column in a datagrid because I'm using the objectid as a unique value to zoom to the graphic on the map. Obviously I don't want to display the objectid to the user so I'm trying to find a way to hide that column.
Here is what I've tried:
declaratively - <th field="1" hidden="true"></th> - no result
programmatically - grid.layout.setColumnVisibility(1, false); - hides the whole grid
css - <th field="1" style="display:none"></th> - no result
Any ideas?
I don't have this code published to the web yet but I can if needed.
The whole table:
<table dojotype="dojox.grid.DataGrid" jsid="grid" id="grid" ><thead><tr><th field="0" width="225px" >Results</th></tr><th field="1" hidden="true"></th></tr></thead></table>
TONIFAIRBANKS
New Contributor III
Did you ever figure out how to hide the Object ID field?
KenBuja
MVP Esteemed Contributor
dGrid, the replacement for DataGrid, has a way to hide columns.
YungKaiChin
Like Ken Buja suggests, use dGrid instead.
With dGrid, you can hide a column when it is created or in css.
Since I don't know how to use DataGrid (anymore).
I think you may be able to use "hidden" as one of the parameters inside th tag with DataGrid.
Example:
<th ... hidden="true">Column Name</th>
<th ... hidden="false">Column Name</th>
TONIFAIRBANKS
New Contributor III
Thanks.
