GraphicsLayer behind MapImageLayer?
321
11-25-2020 02:29 PM
not_esri
Is it not possible to put a GraphicsLayer behind a MapImageLayer?
I have a MapImageLayer that contains an electric span sublayer, and I have a Flask web services that traces from a selected span upstream back to the substation and it returns all the connected span's OBJECTIDs, which I then use to query and display the results in the GraphicsLayer.
However, no matter what order I add the GraphicsLayer, it's always on top of the MapImageLayer but I want it to be underneath so that the user can still see the spans and other layers in the MapImageLayer.
Is this not possible?
ManishPatel
Hi @not_esri ,
This is not possible.
Graphics layers can be reordered within the group of graphics layers. However, the graphics layer in Map.graphics is always on top. Also, all graphics layers are always on top of TiledMapServiceLayers andDynamicMapServiceLayers.
Alternatively, you can create an empty feature layer and add the features to the empty layer when required to display the results and this will allow you to control the layer order.
Hope this helps.
Cheers,
Manish
Cheers,
Manish
ManishPatel
Hi @not_esri ,
Hope this helps.
Cheers,
Manish
Cheers,
Manish
not_esri
Alright, thanks, I'll try a client-side FeatureLayer
