Getting error while implementing getRoute() function
2515
15
04-14-2021 07:21 AM
SahilBansal
While implementing route and directions in my application but getting the following errors in the getRoute() functions.
Property 'solve' does not exist on type 'RouteTaskConstructor'.
Property 'route' is missing in type '{ directions: { features: any; }; }' but required in type '{ route: Graphic; }'.
Type 'number[]' is missing the following properties from type 'Color': a, b, g, r, and 7 more.
The expected type comes from property 'color' which is declared here on type 'Symbol'
Cannot assign to 'classList' because it is a read-only property.
Property 'directions' does not exist on type '{ route: Graphic; }'.
PFB the code snippet:
const getRoute = () => {
      const routeParams = new RouteParameters({
        stops: new FeatureSet({
          features: view.graphics.toArray()
        returnDirections: true
      RouteTask.solve(routeParams)
      .then((data: { routeResults: { routeGraphic; }[] | { directions: { featuresany; }; }[]; }) => {
        data.routeResults.forEach((result: { routeGraphic; }) => {
          result.route.symbol = {
            type: 'simple-line',
            color: [5150255],
            width: 3
          view.graphics.add(result.route);
        if (data.routeResults.length > 0) {
            const directions = document.createElement('ol');
            directions.classList = 'esri-widget esri-widget--panel esri-directions__scroller';
            directions.style.marginTop = '0';
            directions.style.padding = '15px 15px 15px 30px';
            const features = data.routeResults[0].directions.features;
            features.forEach((result: { attributes: { textstringlengthnumber; }; }, iany=> {
              const direction = document.createElement('li');
              direction.innerHTML = result.attributes.text + ' (' + result.attributes.length.toFixed(2) + ' miles)';
              directions.appendChild(direction);
            view.ui.empty('top-right');
            view.ui.add(directions'top-right');
UndralBatsukh
Glad it is working. Can you set this question as resolved?
Thanks, -Undral
SahilBansal
Could anyone please help me with this issue?
UndralBatsukh
Hi there,
From what I can see you are using the RouteTask module to call solve like this RouteTask.solve(). Solve is not a static method on RouteTask. Have you created a new instance of the RouteTask? Use the instance of RouteTask to call the  solve method. This sample shows how to set up RouteTask:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=tasks-route
Hope that is the issue.
-Undral
SahilBansal
Thanks for the reply!
I have created an instance and now I am getting the below errors.
Property 'routeResults' does not exist on type 'RouteResult'.
Here is the code snippet.
      routeTask.solve(routeParams)
      .then((data=> {
            color: [5150255],
            width: 3
SahilBansal
      .then((data=> {
            color: [5150255],
            width: 3
UndralBatsukh
Looks like you are using TypeScript. Autocasting is not allowed unless you are setting parameters in the class constructor. The following code needs to be update. See the updated code right below it.
     color: [5, 150, 255],
     width: 3
// IMPORT THE FOLLOWING MODULE
import SimpleLineSymbol = require("esri/symbols/SimpleLineSymbol");
// Then CHANGE YOUR CODE TO
result.route.symbol = new SimpleLineSymbol({
  width: 3
As for this error: Cannot assign to 'classList' because it is a read-only property. The following code is the problem. See the fix right below it.
// NEEDS TO BE CHANGED TO
directions.classList.add("esri-widget", "esri-widget--panel", "esri-directions__scroller");
SahilBansal
Thanks for the solution.
But still this error Property 'routeResults' does not exist on type 'RouteResult is still there.
UndralBatsukh
That is because the RoutResult class does not have a property called routeResults. Please take a look at the SDK doc for RouteResult and modify your code.
SahilBansal
RouteResult is having only 4 properties i.e direction, route, stop and routeName but whenever i am trying to use any relevant one with forEach loop..its giving me an error.
SahilBansal
The routeresults properties are giving me below error while implementing with foreach loop.
directions: Property 'forEach' does not exist on type 'DirectionsFeatureSet'.
route: Property 'forEach' does not exist on type 'Graphic'.
stops: Property 'route' is missing in type 'Graphic' but required in type '{ route: Graphic; }'.
routeName: Property 'forEach' does not exist on type 'string'.
