fully movable popup/floating pane
4197
8
01-09-2015 06:06 AM
AdrianMarsden
Regular Contributor II
I think the answer is no to this one, but someone may have a clever fix
In my old ArcIMS application, the results of a ID task were pushed to a new html page in a popup, and therefore it could be moved outside of the parent browser - so when there were a lot of results it could be moved to a second monitor without covering the map.
In my API replacement I use a customized floating pane to show this info so is limited to the parent window.
As this pane has extra controls like a flash and highlight feature I can't even generate html from the ID results and push it to a new html page as the references to the objects within the map would not be kept.
So, any clever ideas people?
Cheers
ACM
RobertScheitlin__GISP
Adrian,
   Communication between a parent and a popup window and vice versa to interact with the map is very doable. You can see an example of it in my Street View Widget for WAB.
Google Street View Widget 1.1
HaroldBostic
Occasional Contributor II
You may want to consider leveraging this API if you can.  May be the same concept Robert posted, I have not checked out his link
HTML5 window.postMessage
AdrianMarsden
Thanks for that - I just tried the API demo, and it went splut - didn't work at all 😞
Adrian,
   Yep it did not work for me either. I just uses simple parent child window communication in my widget.
AdrianMarsden
Do you use jquery for this?
Nope this is simple HTML stuff that does not require any library (the window communication part).
AdrianMarsden
OK - I'll research - not something I've done before - many thanks
AdrianMarsden
gosh, so simple "window.opener" - I never knew.  Or if I did I'd forgotten
