Export Web Map Task Output_File
211
01-13-2020 02:23 PM
GregoryBologna
Occasional Contributor II
Can I set the Output_File file name when doing an export?
var params = {
   httpMethod: 'POST',
   Web_Map_as_JSON: Web_Map_as_JSON,
   Format: 'PNG32',
   Layout_Template: 'MAP_ONLY',
   f: 'json'
Scheme
Parameter: Output_File
Data Type: GPDataFile
Display Name Output_File
Description: The output file name. The extension of the file depends on the Format parameter.
Direction: esriGPParameterDirectionOutput
Default Value:
Parameter Type: esriGPParameterTypeRequired
Category:
