Export Map
1588
14
07-28-2012 06:12 AM
VenkatChakaravarthy
I am wondering if there is any way to save the map (as jpg or png or gif or tiff ) when the map is loaded in the browser. I am trying to avoid the user click to export the map after the map is loaded. I have attached a sample map.
Thank you for reading this and I appreciate any advise.
MostafaFouly
i think a good way to do that will be implementing getting a screen shot and opening the SaveAs diagram to save it as a .jpg or .png...
you can create your own custom menu via javascript, let's say onRightClick you open your custom menu with saveAs button, and the saveAs button includes getting a screen shot as mentioned above.
grtz,
mostafa.
CoreyAlix
The only client-side solution I am aware of is querying all the the imagery URLs and relevant styling information in each layer of interest and generating the HTML for a new window containing those URLs and then printing that window.  Of course ArcGIS 10.1 has a print service.
VenkatChakaravarthy
grtz,
mostafa.
Hi Mostafa, thank you for the response. Is there any way to do this after the map load, instead of user saving the map.
VenkatChakaravarthy
Hi Corey,
Thank you for your response. Is there a code snippet for the solution that you recommend?
derekswingley1
RahulMetangale1
Occasional Contributor II
If you are using 10 you can use Advance print SOE:
http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
MostafaFouly
as Derek mentioned you can use the print widget then, check the following sample:
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/widget/widget_print_esri_request.html
CoreyAlix
Well, no there is not a snippet that I would recommend but here's what I did.  First I created a "printer" constructor:
 createPrinter: function ()
  var transformers = {};
  return {
   register: function (transformName, transform)
    transformers[transformName] = transform;
   print: function (options)
    var self = this, map, output, features;
    map = dojo.byId(options.map);
    output = dojo.byId(options.target) || dojo.create("div");
    features = dojo.filter(options.features, function (f)
     return transformers.hasOwnProperty(f);
    dojo.forEach(features, function (f)
     self.render(output, transformers(map, options));
    return output;
   render: function (div, imagery)
    var images = imagery.images;
    if (images)
     images = dojo.map(images, function (item)
      var img = dojo.create("img", {
       src: item.src
      dojo.style(img, {
       position: "absolute",
       left: item.x + "px",
       top: item.y + "px",
       opacity: item.opacity || 1,
       zIndex: item.zIndex || 99
      if (item.w)
       dojo.style(img, {
        width: item.w + "px",
        height: item.h + "px"
      return img;
    dojo.forEach(images, function (img)
     div.appendChild(img);
    if (imagery.polylines)
     // render vector data
Then I instantiate and extend the printer to handle markers and layers:
 print: function (node)
  var printer;
  printer = createPrinter(acme.gis.mapdrawer.render.createPrinter());
  var div = printer.print({
   map: agsMap,
   features: ["layers", "markers"],
   target: node
  dojo.style(div, {
   position: "relative",
   overflow: "hidden",
   width: $.todo("960px", "move to frame?"),
   height: $.todo("600px", "move to frame?")
  return div;
 function createPrinter(print)
  print.register("markers", function (map)
   var images = [];
   dojo.forEach(map.graphicsLayerIds, function (id)
    var layer = map.getLayer(id);
    dojo.forEach(layer.graphics, function (graphic)
     var geom, symbol, point;
     geom = graphic.geometry;
     symbol = graphic.symbol;
     if (geom.type === "point" && symbol.url)
      point = map.toScreen(geom);
      images.push({
       src: symbol.url,
       x: point.x,
       y: point.y,
       zIndex: 10
   return {
    images: images
  print.register("layers", function (map)
   var images = dojo.query(".layersDiv div img", map.root);
   var root = dojo.position(map.root);
   images = dojo.map(images, function (img)
    var pos;
    pos = dojo.position(img);
    return {
     src: img.src,
     x: pos.x - root.x,
     y: pos.y - root.y,
     opacity: dojo.style(img, "opacity"),
     zIndex: dojo.style(img, "zIndex")
   return { images: images };
  return print;
And it works well enough for me.  Surely you'll need to customize this code a good bit but right-clicking and doing a save-as is not going to work if you have tiled imagery and it's not going to pick up any markers.  The only sensible solution I am aware of is something like MapFish Print or another server-side printing solution where the user can download a PDF of the map.
CoreyAlix
Related question - can the PrintingTools geoprocessing service be copied/downgraded from 10.1 to 10?  Technical/legal restrictions?
