Example for Projection
3010
02-27-2019 05:13 AM
MHahn
New Contributor II
Is there a working example for
projection | API Reference | ArcGIS API for JavaScript 4.10
I pasted the example to JSFiddle
Edit fiddle - JSFiddle
I got the error_
Cannot read property '_getTransformation' of null
What do i miss?
Tags (1)
RobertScheitlin__GISP
Matthias,
  You have to load the module first:
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
    <script src="https://js.arcgis.com/4.10/"></script>
    <script>
      require([
        "esri/geometry/projection",
        "esri/geometry/SpatialReference",
        "esri/geometry/Extent"
      ], function (projection,SpatialReference,Extent) {
      const cs1 = new SpatialReference({
  	  wkid: 4272 //PE_GCS_ED_1950
      const cs2 = new SpatialReference({
  	  wkid: 4167
      const extent = new Extent({
          xmin: -186.0,
          ymin: -42.0,
          xmax: -179.0,
          ymax: -38.0
      projection.load().then(function(evt) {
          const geogtrans = projection.getTransformations(cs1, cs2, extent);
          geogtrans.forEach(function(geogtran, index) {
            geogtran.steps.forEach(function(step, index) {
              console.log("step wkid: ", step.wkid);
  </script>
</head>
<body >
Test
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Matthias,
<!DOCTYPE html>
<html>
  <head>
    <script>
      require([
  	  wkid: 4167
          xmin: -186.0,
          ymin: -42.0,
          xmax: -179.0,
          ymax: -38.0
  </script>
</head>
<body >
Test
</body>
MHahn
New Contributor II
Thank you Robert. Now it works!
The documentation at the esri page is wrong!
...Maybe they should fix that. Wrong documentation is just frustrating ...
Matthias,
   Actually the load requirement is stated in the help documentation:
https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-projection.html#load
Loads this module's dependencies. This method must be called before projecting geometries.
I agree that it should be part of the code snippets though.
Heather Gonzago
