Error 404 when try to configure webadaptor for portal for arcgis
11697
13
07-12-2017 06:28 AM
ScaiConsulting
After installing ArcGIS Server and Arcgis Portal, I am trying to configure the web adaptor to use it with portal but when I navigate this url: https://localhost/arcgis/webadaptor/portal , I have error 404 or a white page without any message.
Arcgis Server is 10.5
Arcgis Portal is 10.5
Arcgis Web adaptor is 10.5
OS is Windows 10
I am using web adaptor with IIS.
How can I solve this? Is there a bug with the web adaptor??
Please help me!!
RandallWilliams
Did the hostname binding match one the Subject Alternative Names defined in the cert? If so, I'd get them to log a bug.
RoyceSimpson
Occasional Contributor III
Removing the host name in the binding setting solved it for me too.
feralcatcolonist_old
@BradLingenfelder1  You saved my life. I owe you, what my people call, a life debt.
Also, did you change the binding back after initializing your web adaptor?
Likes an array of [cats, gardening, photography]
ChristianJohnsonMWPipe
Can I buy you a cold beverage as a thank you? After going round and round trying different things removing the Hostname worked!
Thank you so much!!!
