Hi All,
I have to modify features, but geometries only, attributes should not be shown nor updated.
So, as by default Editor fieldConfig is exposing all attributes, I tried to empty it with null, [] or [{}].
Unfortunately all these values are causing many issues and errors in the javascript console.
https://codepen.io/Chris_Siveco/pen/dyvKzNP
Is there a way to edit only geometries with the Editor widget ?
Regards
Chris
How about leaving the fields in but not allowing them to be edited, such as:
fieldConfigs: [{
label: "Hazard Type",
editable: false,
direction: "asc"
label: "Description",
editable: false,
direction: "asc"
There is also a 'showNoValueOption' setting that might work (not much help on it). Or maybe the 'visibilityExpression' that ties to an Arcade expression that is always false?
fieldConfigs: [{
editable: false,
direction: "asc"
editable: false,
direction: "asc"
Actually, with something like I made it work :
const pointInfos = {
layer: pointLayer,
fieldConfig: [{
label: "Hazard type",
editable: false,
visibilityExpression:"1==2" //Here is the Trick not to have any attributes editable nor shown !
BUT, after reviewing my codepen code, I also made it work with a regular fieldConfig: []
So, may be there was a bug in my original codepen.
Thank you Jeffrey
That second option looks a lot simpler 😁
