Editor Widget issue when setting no attributes updatable - geometry only
856
06-07-2021 07:21 AM
ChristopheS
New Contributor II
Hi All,
I have to modify features, but geometries only, attributes should not be shown nor updated.
So, as by default Editor fieldConfig is exposing all attributes, I tried to empty it with null, [] or [{}].
Unfortunately all these values are causing many issues and errors in the javascript console.
https://codepen.io/Chris_Siveco/pen/dyvKzNP
Is there a way to edit only geometries with the Editor widget ?
Regards
Chris
JeffreyWilkerson
Occasional Contributor III
How about leaving the fields in but not allowing them to be edited, such as:
 fieldConfigs: [{
     label: "Hazard Type",
     editable: false,
     direction: "asc"
    label: "Description",
    editable: false,
     direction: "asc"
There is also a 'showNoValueOption' setting that might work (not much help on it).  Or maybe the 'visibilityExpression' that ties to an Arcade expression that is always false?
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-FeatureForm-FieldConfig.h...
JeffreyWilkerson
 fieldConfigs: [{
     editable: false,
     direction: "asc"
    editable: false,
     direction: "asc"
ChristopheS
New Contributor II
Actually, with something like I made it work :
 const pointInfos = {
              layer: pointLayer,
              fieldConfig: [{
                label: "Hazard type",
                editable: false,
                visibilityExpression:"1==2" //Here is the Trick not to have any attributes editable nor shown !
BUT, after reviewing my codepen code, I also made it work with a regular fieldConfig: []
So, may be there was a bug in my original codepen.
Thank you Jeffrey
JeffreyWilkerson
That second option looks a lot simpler 😁
