Edit feature slow performance first time
1024
9
01-29-2018 07:02 AM
RodrigoFelga
New Contributor III
I have the following scenario:
A MXD containing about 60 layers divided in 5 featuredatasets, 2 of that datasets is registered as versioned.
The MXD is published in Arcgis Server with the Resource os MapServer and FeatureServer enabled. The servevice is configured with a maximum instances of 10 and minimum of 2. When I start, the service starts with 2 instaces "up" and I have no problem showing the map but when I try to edit a fetaure the first editing operation takes about 90 seconds to run (the service show that 1 instance is in use on ArcGIS Server Manager). The followings editing operations performs normally taking about 2 seconds to execute. This problem occurs only when edditing a feature with this featuredataset registered as versioned, with non versioned always runs fast.
My question is: Why this delay on the first operation if the instance is already running? Its possible to solve that?
P.S.: Sorry for my poor English.
RobertScheitlin__GISP
Rodrigo,
  What version of ArcGIS Server are you using?
RodrigoFelga
New Contributor III
ArcGIS Server 10.5
Rodrigo,
   I am not real sure what your issue is,
but what are your services settings for
Specify Recycling Settings
Recycling shuts down the process and restarts it at regular intervals to help maintain performance and stability.
and
Specify Health Check Settings
Periodically check and repair data connections for idle instances
Check and repair instances every:
RodrigoFelga
New Contributor III
Recicle every 24 hours starting 4:30 am
Check and repair instances every: 30 minutes
Rodrigo,
   I recycle my high demand service every 6 hours.
RodrigoFelga
New Contributor III
Hi Robert, I will change this setting but I don't think that's the problem decause the problem occurs the first time I try to call applyedits after the service is started, the others calls is ok.
RodrigoFelga
New Contributor III
Hi Robert, the problem continues. Any other advices?
Rodrigo,
  Could be something like this. I am not sure which enterprise DB you are using though.
SQL Server Wake-up
RodrigoFelga
New Contributor III
Thanks for your reply, I'm using oracle 11g and the problem only occurs with versioned datasets. I will send this to ESRI to see if they have a clue (I doubt)
