I remembered that Robert Scheitlin had a good sample for search(search in field, search by draw polygon and...) in flex, that was very very useful. is there any sample in arcgis java script api?
regards
Anjelina,
For indirect url issues look in the FAQ:
FAQs—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Also refer to this blog:
Anjelinia,
The eSearch widget is available for WAB here:
https://community.esri.com/docs/DOC-1731-enhanced-search-widget-version-211-080116
I have not portal for arcgis and can not use WAB. Is possible that I apply esearch in arcgis java?
No it is WAB specific. You do not need Portal to use WAB. You can down load the WAB Dev and host on your own web server like you did Flex Viewer.
I,m installing WAB and I have a problem. I have not portal for arcgis and I have developer account. I did these steps:
1- I install node.js
2- I run startup.bat
3- I see a page in my browser that neet to put: specify the URL to your ArcGIS Online organization or portal for ArcGIS
4- I have arcgis developer account and I put my arcgis online address but I have this error:
Error: 400
why?
Anjelina,
