hi I am unable to handle dojo parser while accessing on development environment everything working fine bu at stating environment I am getting error "dojo/parser::parse() error Error: string.substitute could not find key "loadingState" in template"
FWIW: I've found the error can be triggered when the pages language is set (e.g. <html lang="en">). I've encountered this when using API version 3.26 and dojox/grid/EnhancedGrid.
According to AODA recommendation "lang" attribute should be added with <html> tag. But if we add the "lang" attribute, then we are facing the same issue. We are using ArcGIS Javascript API 3.3.
Please let us know how we can handle this issue.
Using the proper value works fine:
<html lang="en-US">
