Detect change in zoom when complete
5456
8
06-19-2017 11:58 AM
AlanMervitz
I'm trying to detect when a map has been zoomed in or out, and when that is complete to execute a function. I have tried using watchUtils.watch on both the view.zoom and view.extent properties, but am finding that the callbacks get executed too many times.
Here's the TypeScript code I'm using, where the console.log statements are getting executed too many times:
constructor(basemap: string = "streets", container: string = "viewDiv", center: number[] = [-104.61, 50.45], zoom: number = 12) {
    this.map = new Map({
        basemap: basemap
    this.view = new MapView({
        container: container,
        map: this.map,
        center: center,
        zoom: zoom
    watchUtils.watch(this.view, "zoom", function (zoom) { console.log(`zoom is now ${zoom}`) });
    watchUtils.watch(this.view, "extent", function (extent) { console.log(`extent is now ${extent}`) });
Here's what the output looks like in the console:
Is there a way to detect the change only when the zoom is complete? Perhaps there's another approach for accomplishing this than watching these properties?
Tags (1)
ThomasSolow
Occasional Contributor III
Interesting solution, if it works I'd go with it.
Another option would be to use a debounce function.  So each time the zoom changes that function would be called but the actual logic would be delayed until the function hasn't been called in some user defined amount of time (maybe 200 ms would be good for something like this).
I always copy the underscore.js debounce function when I need this: underscore.js
RobertScheitlin__GISP
Alan,
   You should watch the updating property of the view for a false condition after the zoom property changes.
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#updating
AlanMervitz
Hi Robert,
Thanks for the suggestion, I've given that a quick try but it doesn't seem to be working reliably. The updating status seems to be changing multiple times throughout the zooming process.
    watchUtils.watch(this.view, "zoom", this.onZoomChange);
onZoomChange(newValue: number, oldValue: number, propertyName: string, target: MapView) {
    console.log(`zoom is ${newValue}`);
    if (target.updating) {
        console.log("zoom in progress");
    else {
        console.log("finished zoom");
Here's a working approach I've found, any feedback?
    if (newValue % 1 !== 0) {
    else {
Alan
Alan,
   Something more like this:
watchUtils.watch(this.view, "zoom", function(){
  watchUtils.whenFalseOnce(this.view, "updating", yourFunction);
AlanMervitz
I've tried that but the whenFalseOnce callback is getting triggered multiple times. This would have been ideal if it had worked.
RomanKönig
New Contributor III
I found it more useful to check the stationary attribute of the view than updating, as updating waits for export, etc. responses.
ThomasSolow
AlanMervitz
The debounce approach is working beautifully, thanks!
AbdulKhan
Alan,
I'm looking to do that same thing and was wondering - did you have any lag issues when using the denounce approach? Was there a delay between when the map is actually zoomed and when the zoom event is done?
