Customize Editor Widget Toolbar
3519
7
07-20-2012 12:02 PM
DonCaviness
New Contributor III
I have implemented the editor widget in my application but I would like to remove some of the buttons/functions from the toolbar.  This seems simple enough but I haven't been able to figure it out yet.  I would like to remove the delete, feature creation button and remove all options but 'New Selection' from the selection drop down.  How would I go about accomplishing what I'm trying to do?  I have search the forums and the API reference but I haven't seen how to do this.
Don
SiqiLi
by Esri Contributor
You can modify the toolbarOptions to include/exclude merge, cut, and reshape tools on the toolbar. But I believe all the others tools have been embedded in the toolbar by design. I don't think you can remove them.
toolbarOptions: {
    reshapeVisible: false,
    cutVisible: false,
    mergeVisible: false
DonCaviness
New Contributor III
Thanks Shuping, that is what I figured.  I am taking advantage of the toolbarOptions but some of the hard coded buttons is what I was looking to toggle on/off.  It would be nice if a new version of the API would allow the entire toolbar to be customized, not just the toolbarOptions.
JeffPace
Which buttons? would it be sufficient just to hide them?
DonCaviness
New Contributor III
Hiding them is a valid solution for my purposes. I'm looking to remove the delete, feature creation button and remove all options but 'New Selection' from the selection drop down.  Is there a way to just hide them?
JeffPace
Its going to be harder than I thought.  ESRI does not ID the components well.
The create feature is a table with id="esri_dijit_editing_tools_Editing_0"
Delete has no id by a widgetid of "btnDelete2"
thats a shame.
VaibhavGrigo3
New Contributor II
Hi Everyone,
I was able to remove the point from the simple toolbar options. Here is the code:
myEditor.on("load", function()
  var toolBarDiv= dom.byId("esri_dijit_editing_tools_Editing_0");
  domStyle.set(toolBarDiv, "display", "none");
It will hide that tool from the editor tools. But i am still struggling to eliminate the selection options(Add To Selection, Subtract from Selection).
VaibhavGrigo3
New Contributor II
Please add this in the style tag and then you will be able to remove those two options from the dropdown.
#btnAddToSelection
display:none;
#btnSubtractFromSelection
display:none;
