Create Widget Toolbar using DOM element(s)?
2548
08-09-2019 12:47 PM
Arne_Gelfert
The great thing about Web AppBuilder to me is that you get this general layout for your app out of the box. Whether you like the available themes or not, at least you have something resembling a frame and toolbar to house your map. But that's the only thing I like about WAB, and that's why I keep coming back to working with the API.
What I'm missing there is an easy way to build something like a toolbar. View UI is clean and simple enough. But with top-right, bottom-right, top-left, and bottom-left at my disposal, I'm left with few options. Now, I'm not trying to clutter up my apps. I'm a big champion of targeted or focused maps rather than those mother-of-all-web-app type.
I've looked at Bootstrap or Calcite-Bootstrap, and they look great. But for what I'm right now, that's more than I need. I tried a few things with the DOM, and can't seem to get them to work. For example, why doesn't this work...?
const toolbarTable = document.createElement("table");
toolbarTable.style.opacity = "1";
toolbarTable.style.width = "200px";
tollbarTable.style.backgroundColor = "#ffffff";
view.ui.add(toolbar,{
   position: "top-left"
const row = table.insertRow(0);
const cell1 = row.insertCell(0);
const cell2 = row.insertCell(1);
const cell3 = row.insertCell(2);
//Note: I'm not planning to add three Home buttons
// just used this for testing widget behavior
const homeBtn1 = new Home({
    view : view,
    container: cell1
const homeBtn2 = new Home({
    view : view,
    container: cell2
const homeBtn3 = new Home({
    view : view,
    container: cell3
What this does against my expectations create a table with three rows, each with one cell, i.e. the three widgets are stacked one upon the other.
How, if I try just putting some text in the cells - either using .innerHTML or as below, that works fine.
cell1.append("Cell 1");
cell2.append("Cell 2");
cell3.append("Cell 3");
Any idea how to make this work, or other suggestions for creating a horizontal strip or toolbar to hold a number of widgets?
RobertScheitlin__GISP
Arne,
  So something like this?
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>Home button - 4.12</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.12/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/views/SceneView",
        "esri/widgets/Home"
      ], function(Map, SceneView, Home) {
        var map = new Map({
          basemap: "streets",
          ground: "world-elevation"
        var view = new SceneView({
          container: "viewDiv",
          map: map,
          center: [-56.049, 38.485, 78],
          zoom: 3
        toolbarTable.style.backgroundColor = "#ffffff";
        view.ui.add(toolbarTable,{
        const row = toolbarTable.insertRow(0);
        const cDiv1 = document.createElement("div");
        cell1.appendChild(cDiv1);
        const cDiv2 = document.createElement("div");
        cell2.appendChild(cDiv2);
        const cDiv3 = document.createElement("div");
        cell3.appendChild(cDiv3);
            view : view,
            container: cDiv1
            view : view,
            container: cDiv2
            view : view,
            container: cDiv3
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
Arne,
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <link
      rel="stylesheet"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/widgets/Home"
        var map = new Map({
          basemap: "streets",
          map: map,
          zoom: 3
            view : view,
            container: cDiv1
            view : view,
            container: cDiv2
            view : view,
            container: cDiv3
    </script>
  </head>
  <body>
  </body>
</html>
Arne_Gelfert
Nice!!! I simply forgot to create mew div's for each table cell. Added some padding, and this will be a great start. Thanks, Robert! Very helpful!
