create symbology from json not working correctly
5197
04-10-2015 02:08 PM
JoseLuis_Serrano
I am trying to apply some symbology form a Json like string. I have a point, polyline and polygon datasets and only the polyline and polygon layers are getting symbolized, although not like defined in the Json. So, my guess is that I am doing something really wrong.
Here is the code, in case someone can point me in the right direction.
Thanks!
function getSimpleRenderer(tmpLayer) {
            var jsonSymbologies = {};
            jsonSymbologies.subs_point = '{"color":[250,0,250,255],"size":12,"angle":-30,"xoffset":0,"yoffset":0,"type":"esriSMS","style":"esriSMSCircle","outline":{"color":[255,0,0,255],"width":1,"type":"esriSLS","style":"esriSLSSolid"}}';
            jsonSymbologies.trans_polyline = '{"color": [0,255,0,255], "width": 1, "type": "esriSLS", "style": "esriSLSLongDashDot"}';
            jsonSymbologies.region_polygon = '{"color": [255,0,0,255], "type": "esriSFS","style": "esriSFSSolid", "outline": {"color":  [230,230,230,255], "width": 0.5, "type": "esriSLS", "style": "esriSLSDashDot"}}';
            jsonSymbologies.buildable_polygon = '{"color": [255,255,0,255], "type": "esriSFS","style": "esriSFSSolid", "outline": {"color":  [230,230,230,255], "width": 0.5, "type": "esriSLS", "style": "esriSLSDashDot"}}';
            var layerSemanticTypes = ["subs", "trans", "region", "buildable"];
            var nameParts = tmpLayer.split("_");
            // reduce the synonyms in the semantic types
            var nameSemantic = nameParts[0].toLowerCase();
            arrayUtils.some(layerSemanticTypes, function (dictSemanticType) {
                if (nameSemantic.indexOf(dictSemanticType) > -1) {
                    nameSemantic = dictSemanticType;
                    return false;
            // reduce the synonyms in the geometry types
            var nameGeom = tmpLayer.split("_")[nameParts.length - 1].toLowerCase();
            if (nameGeom === "pnt") {
                nameGeom = "point";
            } else if (nameGeom === "line") {
                nameGeom = "polyline";
            // get the appropiate renderer
            var symbol;
            var baseSymbol;
            var tmpJson;
            if (nameGeom === "point") {
                tmpJson = JSON.parse(jsonSymbologies[nameSemantic + "_point"]);
                baseSymbol = symbolJsonUtils.fromJson(tmpJson);
                symbol = new SimpleMarkerSymbol(baseSymbol)
            } else if (nameGeom === "polyline") {
                tmpJson = JSON.parse(jsonSymbologies[nameSemantic + "_polyline"]);
                symbol = new SimpleLineSymbol(baseSymbol)
            } else if (nameGeom === "polygon") {
                tmpJson = JSON.parse(jsonSymbologies[nameSemantic + "_polygon"]);
                symbol = new SimpleFillSymbol()
            }else{
                console.log(nameGeom + " is an undefined geometry type!");
                return false;
            return new SimpleRenderer(symbol);
RobertScheitlin__GISP
Ragadmin,
  So basically your code for make the renderer is trying to do to much. This should work:
        } else {
          return false;
        return new SimpleRenderer(baseSymbol);
The symbolJsonUtil is already creating a specific symbol object based on the JSON so there is no need to try and create the particular symbol type again.
Ragadmin,
   Kind of hard to decipher your code without knowing what a tmpLayer object looks like.
JoseLuis_Serrano
Sorry, the context of the application is that I have a map with an ArcGISDynamicMapServiceLayer that has two dynamic workspaces defined. The application has two buttons, when I click the proj1 button, it reads three shp files and adds them to the service using the dynamicLayerInfos array. The shp files need a symbology, so I use the jsonSymbologies object to store a few symbologies in Json format.
Here is the whole script
(btw, I'm new to programming, so don't get too scared of the code)
var map, usaLayer;
require([
  "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/layers/DynamicLayerInfo", "esri/layers/LayerDataSource",
  "esri/layers/LayerDrawingOptions", "esri/layers/TableDataSource",
  "esri/Color", "esri/renderers/SimpleRenderer", "esri/symbols/jsonUtils",
  "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
  "dojo/dom", "dojo/dom-construct", "dojo/dom-style",
  "dojo/_base/lang", "dojo/query", "dojo/on",
  "dojo/parser", "dojo/json", "dojo/_base/array", "dojo/dnd/Source", "dijit/registry", "dojo/ready",
  "dijit/form/Button", "dojo/domReady!"
], function (
  Map, ArcGISDynamicMapServiceLayer,
  DynamicLayerInfo, LayerDataSource,
  LayerDrawingOptions, TableDataSource,
  Color, SimpleRenderer, symbolJsonUtils,
  SimpleFillSymbol, SimpleMarkerSymbol, SimpleLineSymbol,
  dom, domConstruct, domStyle,
  lang, query, on,
  parser, JSON, arrayUtils, Source, registry, ready
    //function init() {
        parser.parse();
        var dynamicLayerInfos;
        map = new Map("map", {
            center: [-93.636, 46.882],
            zoom: 6,
            slider: false
        var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(initBasemap);
        usaLayer = new ArcGISDynamicMapServiceLayer("https://arcgis.edf-re.com/rag/rest/services/Other/dynamicworkspaceservice/MapServer", {
            "id": "abc",
            "opacity": 1
        //here you create the DynamicLayerInfos that you need to add the new layers to the service
        usaLayer.on("load", function (e) {
            dynamicLayerInfos = e.target.createDynamicLayerInfosFromLayerInfos();
            dynamicLayerInfos = []; // this eliminates all the existing layers in the map service
        registry.byId("proj1").on("click", addProject);
        registry.byId("proj2").on("click", addProject);
        // add the layer to the existing map service
        map.addLayer(usaLayer);
        function addProject() {
            console.log("start");
            // get the workspaceID based on the selected project
            var projID = this.onClick.target.id;
            var workspaceID = projID;
            // read the folder contents based on the selected workspaceID
            var layerList = [];
            if (workspaceID === "proj1") {
                layerList = ["substation_v12_point", "transmission_v12_polyline", "regions_v12_polygon"];
            } else{
                layerList = ["subs_v1_pnt", "trans_v1_polyline", "buildable_v1_polygon"];
            var options = []; // for the renderers
            arrayUtils.forEach(layerList, function (tmpLayer, i) {
                var dynamicLayerInfo = new DynamicLayerInfo();
                dynamicLayerInfo.id = dynamicLayerInfos.length;
                dynamicLayerInfo.name = tmpLayer;
                var dataSource = new TableDataSource();
                dataSource.workspaceId = workspaceID; // not exposed via REST :(
                dataSource.dataSourceName = tmpLayer;
                var layerSource = new LayerDataSource();
                layerSource.dataSource = dataSource;
                dynamicLayerInfo.source = layerSource;
                dynamicLayerInfos.push(dynamicLayerInfo);
                // get the right renderer here
                var renderer = getSimpleRenderer(tmpLayer);
                if (renderer !== false) {
                    console.log("ok renderer");
                    var drawingOptions = new LayerDrawingOptions();
                    drawingOptions.renderer = renderer;
                    options[i+1] = drawingOptions;
            // set the dynimicaLayerInfo for all layers and update the map
            usaLayer.setDynamicLayerInfos(dynamicLayerInfos, true);
            usaLayer.setLayerDrawingOptions(options);
            console.log("end");
                    return false;
                nameGeom = "point";
            var symbol;
            var baseSymbol;
            var tmpJson;
            }else{
                return false;
   // ready(init);
Ragadmin,
        } else {
          return false;
JoseLuis_Serrano
Thank you Robert,
you were right, if I use symbolJsonUtils, I don't need to create the symbol again. I also had a small error assigning the symbology to the correct index in the options[] array.
