I am using the editor widget to edit a feature layer that has 10 fields. When a user updates an attribute, the attribute Inspector infoWindow scrolls back to the top. The user then needs to scroll back down, and click in the next field. This behavior is only exhibited if the field being exited was updated , and the user is tabbing (or mousing) into or out of a field that uses a coded value domain. I don't see this behavior when moving from two adjacent fields that aren't associated with a domain. This happens in both Chrome and IE8. Has anyone seen this? Is there a solution? I know I can increase the size of the info window, but I would really prefer to fix the scrolling issue.
