Arcgis ignores extent definition
322
03-20-2019 04:07 PM
davidzornosa
Hi, In arcgis js 3.25 I have a map that displays only one layer.
Said layer is known to be in srid 4686
var bounds = new Extent({
            "xmin" : -83.00,
            "ymin" : -4.60,
            "xmax" : -66.00,
            "ymax" : 13.0,
            "spatialReference" : {
                "wkid" : 4686
var MAP = new Map("divCont", {
            extent: bounds,
            slider : false,
            logo : false,
            showAttribution : false
var fl = new FeatureLayer(LAYER_URL+ "/0", {
    mode: FeatureLayer.MODE_SNAPSHOT,
    outFields:["*"]
fl.setDefinitionExpression("attribute=2");
MAP.addLayer(fl);
However, no matter what extent i set, Arcgis always ignores it.
Any ideas?
thank you
KenBuja
This works:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.27/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script src="https://js.arcgis.com/3.27/"></script>
    <script>
      var map;
      require([  "esri/map", "esri/geometry/Extent", "esri/layers/ArcGISDynamicMapServiceLayer"
      ], function(Map, Extent, ArcGISDynamicMapServiceLayer) {
        var map = new Map("map", {
          extent: new Extent({xmin:-83.00,ymin:-4.60,xmax:-66.00,ymax:13.0,spatialReference:{wkid:4686}})
        var dynamicMSLayer = new ArcGISDynamicMapServiceLayer("https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapServer");
        map.addLayer(dynamicMSLayer);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
