Arcgis API failed to load (react-arcgis) with Scene
932
04-09-2019 12:11 AM
kawishabbas
I am using react-arcgis for React App. I want to use Scene instead of Map but API does not load with Scene while it works properly with Map module.
import React from 'react';
import { Scene } from 'react-arcgis';
//import { Scene } from '@esri/react-arcgis';
import { Row, Col } from 'reactstrap';
import './south.css'
import SouthWidget from './SouthWidget';
export default class SouthRegion extends React.Component{
    constructor(props) {
        super(props);
        this.state = {
            viewProperties: {
                center: [67.110382, 24.8776361],
                scale: 220000,
                popup: {
                    dockEnabled: true,
                    dockOptions: {
                        // Disables the dock button from the popup
                        buttonEnabled: false,
                        // Ignore the default sizes that trigger responsive docking
                        breakpoint: false,
                        position: "bottom-left"
    render(){
        return (
            <div className="page-wrapper">
                <div className="container-fluid">
                    <Row>
                        <Scene
                            className="scene__container"
                            style={{ width: '100vw', height: '90vh' }}
                            mapProperties={{ basemap: 'satellite' }}
                            viewProperties={this.state.viewProperties}
                        <SouthWidget/>
                        </Scene>
                    </Row>
                </div>
            </div>
Error
EvelynHernandez
SouthWidget is the class you are loading in render, so.. what does SouthWidget contain?
SouthRegion should be rendered?
kawishabbas
South Widget contain map widgets like seach, Layerlist, BasemapGallery etc. But question is that why this code is running with Map?
