Adjusting text symbol attributes on zoom
1073
01-15-2018 10:52 AM
yangwen
My feature layer has text symbols.  I need to dynamically adjust the font size property of the text or hide them altogether, based on the zoom level of the mapview.
What is the pattern to achieve this? I have a watch function on the view.stationary property so I know when the zoom is occurring.  However I can't just loop through the layers and change the fontSize property and expect it to reflect on screen - There is no binding between the layer instances and the DOM.  Do I just need to brut force it - Delete textSymbol graphics and re-add them with a different font-size?
RobertScheitlin__GISP
Yang,
 if using 4.6 there is a refresh method on most layers. Have you tried that?
Yang,
yangwen
I have not.. the API describes it as:
refresh()
Since: ArcGIS API for JavaScript 4.6
Fetches all the data for the layer.
It implies the use case where the Layer is sourced from a service URL..  However it may also include the manual instantiation method.  I'll give it a try.
yangwen
Worked! Thanks!
