Adding Custom Basemaps to Basemap Gallery in 4.3
5370
10
04-10-2017 08:30 AM
NathanSommers1
I have imagery dating back 20 years or so that I need to add to my Basemap Gallery widget in a v4.3 map. Has anyone figured out how to add these custom basemap layers to the widget in this version of the APi?
Here's an example of one of the layers I'd like to add to the Basemap Gallery.
// Mapbox Basemap URL
 var mapbox = new WebTileLayer({
 urlTemplate: "https://api.mapbox.com/styles/v1/mapbox/streets-v10/tiles/256/{level}/{col}/{row}"
 // Mapbox Basemap
 var mapboxBasemap = new Basemap({
 baseLayers: [mapbox],
 title: "Mapbox",
 thumbnailUrl: "includes/images/mapbox.PNG"
This is how I have the Basemap Gallery widget styled right now. I'm using an Expand on it, so it may look different than the normal widget layout.
//Basemap Gallery Widget
 var basemapGallery = new BasemapGallery({
 view: view,
 container: document.createElement("div")
 var basemapGalleryExpand = new Expand({
 view: view,
 content: basemapGallery.domNode,
 expandIconClass: "esri-icon-basemap"
 view.ui.add(basemapGalleryExpand, {
 position: "top-right"
Also, does anyone known the line to hide the default ArcGIS Basemaps in the widget? The old line doesn't/didn't work in this version of the API. (Below is the old line of code that used to hide the default basemaps.)
showArcGISBasemaps: false,
thejuskambi
I don't see the part where you are trying to add your Basemap to the BasemapGallery. Below is the documentation for source in BasemapsGallery
The source for basemaps that the widget will display. This property can be autocast with an array or Collection of Basemaps, a Portal instance, or a URL to a portal instance. The default source is a PortalBasemapsSource that points to the default portal instance set in esriConfig.portalUrl.
You need to create an instance of LocalBasemapsSource, and set the source property of the BasemapGallery. That will clear all the protal basemaps and only your custom basemap will be available.
      var localSource = new LocalBasemapsSource({
        basemaps : [stamen]
        view: view,
        container: document.createElement("div"),
        source: localSource
thejuskambi
        basemaps : [stamen]
        view: view,
        source: localSource
NathanSommers1
Perfect. That's just what I was looking for.
AlifShaikh
Can you Nathan Sommers   post a complete sample code?
Regards,
Alif
JayakumarPD
Create a local base map like this
var Localbasemap = new Basemap({
baseLayers: [
new MapImageLayer({
url: "https://XXXXXXXX/rest/services/XXXXX/XXXXX/MapServer",
title: "Basemap"
title: "basemap",
and add it like this
view: view,
//source:localSource
source: [Basemap.fromId("topo-vector"), Basemap.fromId("hybrid"), Localbasemap]
If youo want more default basemap from esri add Basemap.fromId("what ever required")
Note: please add "esri/layers/MapImageLayer" in required library
syamalaNarem
Hi ,
This code works fine if I provide BaseMaps id like topo-vector, streets , already  defined once.
my local source is not working  not loading any maps and no errors shown in console for my own urls.
My local source titles are displaying correctly , but no action is done when I click on it.
can you please provide one sample for changing/adding our own  custom base map widget   along with layers in the collection of base map for local source.
Also please provide if available in 4.22 version.
 Thanks.
JayakumarPD
What is local source ? Not understood.
ADITYAKUMAR1
Hi @syamalaNarem ,
I am facing a similar issue where I can see the map  in the basemap gallery but on click nothing happens. Did you managed to  solve it?
JayakumarPD
is it possible to share the code
ADITYAKUMAR1
this.customBasemap = new Basemap({
                                      baseLayers: [
                                          new TileLayer({
                                              url: customBasemapServiceUrl,
                                              title: mapservice.MapServiceName
                                      title: mapservice.MapServiceName,
                                      thumbnailUrl: customBasemapServiceUrl + '/info/thumbnail'
