Add layer via URL (JS API)
3520
12
06-09-2017 03:37 PM
ChristopherSchreiber
Occasional Contributor II
Hello all!
I am attempting to add a layer via a URL that the user provides via a text box in the UI.
I can capture the layer URL and work with it in JS, but when I attempt to use it to create a layer, I get the following error in the console "Uncaught TypeError: a.hasChildNodes is not a function"
Here is the JS code that attempts to use the entered URL to create a new Dynamic Map Service Layer:
NOTE: The URL I have been working with is: nowcoast/mapoverlays_political (MapServer)
        var layerURLbox = registry.byId("LayerURLbox");
        on(dom.byId("layerSubmit"), "click", getValue);
        function getValue() {
            console.log(layerURLbox.get("value"));
            layerValue = layerURLbox.get("value")
            getLayerType(layerValue);
        function getLayerType(layerURLValue) {
            if (layerURLValue.indexOf("MapServer")) {
                console.log("Map Service");
                var layer = new ArcGISDynamicMapServiceLayer(layerURLValue, {
                map.addLayer(layer);
The console error I mentioned occurs on line 14, where I attempt to create the new ArcGISDynamicMapServiceLayer.
It does not make it to map.addLayer.
If anyone has any pointers or has tried this before, please let me know!
Thank you!
Chris
Hello all,
I have gotten the code to work with the following layer types:
  1. Map Services
  2. Feature Services
  3. OGC WMS Services*
  4. CSV Layers*
  5. KML Layers*
  6. Image Service Layers
* = require a proxy to be set up. The Esri Resource Proxy can be used.
Here is the code: (URL comes from a textbox)
       function getLayerType(url) {
            var layerType;
            if (url.includes("/FeatureServer"))
                layerType = "FeatureServer";
            else if ((url.includes("wms") || (url.includes("WMS"))) || (url.includes("/MapServer") && url.includes("WMS")))
                layerType = "ogcWms";
            else if (url.includes(".csv"))
                layerType = "CSV";
            else if (url.includes(".kml"))
                layerType = "KML";
            else if (url.includes("/ImageServer"))
                layerType = "ImageServer";
            else if (url.includes("/MapServer") && layerType != "ogcWms")
                layerType = "MapServer";
            addLayer(url, layerType);
        function addLayer(layerURLValue, layerType) {
            var date = getDate();
            switch (layerType) {
                case "FeatureServer":
                    console.log("Feature Service");
                    //Check to see if the URL ends with a number (for a specific sublayer), if it does not, load all sublayers.
                    var match = layerURLValue.match(/\d+$/);
                    if (match) {
                        var layersRequest = esriRequest({
                            url: layerURLValue,
                            content: { f: "json" },
                            handleAs: "json",
                            callbackParamName: "callback"
                        layersRequest.then(
                          function (response) {
                              console.log(response);
                              var popupTitle;
                              if (response.displayField)
                                  popupTitle = "{" + response.displayField + "}";
                              else
                                  popupTitle = response.name;
                              var layer = new FeatureLayer(layerURLValue, {
                                  mode: FeatureLayer.MODE_ONDEMAND,
                                  outFields: ["*"],
                                  infoTemplate: new PopupTemplate({ title: popupTitle, description: "{*}" })
                              var mapLyrNam;
                              if (response.name)
                                  mapLyrNam = response.name;
                              else
                                  mapLyrNam = date;
                              var layerObj = {
                                  layer: layer,
                              addLyrToMap(layerObj, layer);
                    }, function (error) {
                        console.log("Error: Esri Request Failed. Feature Service Layer is unable to load. Error Message: ", error.message);
                        alert("Layer can not be added. See Console for details.");
                    //Load all sublayers
                    } else {
                            url: layerURLValue,
                            handleAs: "json",
                        layersRequest.then(
                              response.layers.forEach(function (sublayer) {
                                      var layer = new FeatureLayer(layerURLValue + "/" + sublayer.id, {
                                          outFields: ["*"],
                                          infoTemplate: new PopupTemplate({ title: sublayer.name, description: "{*}" })
                                      var layerObj = {
                                          layer: layer,
                    break;
                case "MapServer":
                    if (match) {
                        alert("Unfortunatly, loading specific Sublayers for a Map Service is not currently supported. Please remove the specific sublayer from the end of the URL, and try again.");
                        break;
                    var layer;
                    var layerPopup = {};
                        url: layerURLValue,
                        handleAs: "json",
                    layersRequest.then(
                          console.log("Success: ", response);
                              var sublayerCounter = -1;
                                  console.log(sublayer.name);
                                  sublayerCounter++
                                  layerPopup[sublayerCounter] = {
                                      infoTemplate: new InfoTemplate(sublayer.name, "${*}"),
                                      layerUrl: layerURLValue + "/" + sublayerCounter
                                  infoTemplates: layerPopup
                          var mapLyrNam;
                          if (response.documentInfo == undefined || response.documentInfo.Title == "" || response.documentInfo.Title == undefined)
                              mapLyrNam = response.mapName;
                          else
                              mapLyrNam = response.documentInfo.Title;
                          var layerObj = {
                              layer: layer,
                          console.log("Error: Esri Request Failed. Map Service Layer is unable to load. Error Message: ", error.message);
                    break;
                case "ogcWms":
                    console.log("OGC Web Map Service");
                    var layer = new WMSLayer(layerURLValue, {
                    var layerObj = {
                        layer: layer
                    break;
                case "CSV":
                    console.log("CSV Layer");
                    var csvName = layerURLValue.substring(layerURLValue.lastIndexOf('/') + 1);
                    var layer = new CSVLayer(layerURLValue, {
                        infoTemplate: new PopupTemplate({ title: csvName, description: "{*}" })
                    var layerObj = {
                        layer: layer
                    break;
                case "ImageServer":
                    console.log("Image Service");
                    var layer;
                        url: layerURLValue,
                        handleAs: "json",
                    layersRequest.then(
                          layer = new ArcGISImageServiceLayer(layerURLValue);
                          var layerObj = {
                              layer: layer,
                          console.log("Error: Esri Request Failed. Image Service Layer is unable to load. Error Message: ", error.message);
                    break;
                case "KML":
                    console.log("KML");
                    var kmlName = layerURLValue.substring(layerURLValue.lastIndexOf('/') + 1);
                    var layer = new KMLLayer(layerURLValue, {
                    var layerObj = {
                        layer: layer
                    break;
        function addLyrToMap(layerObj, layer) {
            mapInfoLyrs.push(layerObj);
            map.legendList.refresh();
For clarification:
The "mapInfoLyrs" array is used by the Esri "LayerList" to keep track of what layers are on the map. See this link for more details.
The "legendList" object is the Esri "LayerList" widget. When a new layer is added to the map, it must be refreshed.
KenBuja
MVP Esteemed Contributor
Nice implementation. One observation on the getLayerType function. In this condition
you're checking layerType. However, that's always going to be undefined from the initial declaration of layerType, since if it's set in this condition
all other if statements will be skipped.
Thanks Ken Buja‌! I must have left my thinking cap at home that day...
