Add a label from the graphic layer.
5777
04-26-2017 02:12 PM
Sai_AnandPeketi1
New Contributor III
Hello everyone,
                           I want to add the label for the graphic layer.I have a graphic layer contain graphic,symbol and attributes. Now, I want to add a label from that graphic layer. Is it possible, if yes can anyone share the code because i see the sample of the 'esri/layers/LabelLayer' all are coming from the feature layer.
Thanks for the help.
RobertScheitlin__GISP
Then you get the polygons extent using
var pnt = geometry.getExtent().getCenter();
var txtSym = new TextSymbol("Hello World");
var lblGra = new Graphic(pnt, txtSym);
bufferGL.add(lblGra);
Sai,
   Probably the easiest way to do this is to add another graphic (the center of the extent for polygons or polylines) using a TextSymbol as the graphics symbol.
Sai_AnandPeketi1
New Contributor III
Thanks Robert.
Can you share the javascript code for above logic. I am not understand how we can set center of the graphics into the center of the graphics symbol.
Sai,
   What is the geometry type that you are trying to label?
Sai_AnandPeketi1
New Contributor III
Thank Robert.
Polygon type. Need to work on this code Draw polygon feature when ever use click on the map
