Zoom To text in infowindow
1134
03-03-2017 06:48 AM
joelde_freitas
New Contributor III
hi guys,
it's posible to change the zoom To text to other word. if yes, how can i do that
thanks
Tags (3)
RobertScheitlin__GISP
Joel,
   Sure you just need to set the default string for your locale:
var map;
require(["esri/map", "dojo/i18n!esri/nls/jsapi", "dojo/domReady!"],
  function(Map, bundle) {
    bundle.widgets.popup.NLS_zoomTo = "blah blah";
joelde_freitas
New Contributor III
how can i archive it in legacy style?
Joel,
  I never use Legacy coding style so I am not 100% but I think it is:
dojo.require("esri.bundle");
FWI: you really need to more your code to AMD as Legacy is no longer supported in JS 4.x API
joelde_freitas
New Contributor III
Yes i know.  i am planning to use the AMD style later. but now i need to make the app work.
joelde_freitas
New Contributor III
thanks.
