work with GPserver on a selection from a feature layer
1852
06-13-2016 12:21 AM
clementinechasles
Hello everybody,
I have an issue I don't know how to fix. I'm new with the ArcGIS API for JS and with ArcGIS generally.
I have a feature layer with points, provided by a Mapserver.
I would like to :
- select some points on the feature layer (it's ok !)
- then save the selection in a variable (an array Graphic[] I guess ? But is it possible ?)
- add a new point on a map and store it in the variable with the previous selection (I know how to add a point to a map)
- the goal is to have a global selection (existing points and the new point) in a variable that I could reuse to make geotreatments on it (with GPserver and NAserver).
I can't publish Featureserver and I can't work on the server. That's why it seems to me complicated. Maybe I'm wrong ? Do you have please any solution ?
Thank you in advance !
Clementine.
