Why the amount of build files increased after installing ArcGIS JS in the Angular application
628
01-20-2022 01:59 AM
ChFaiza
I have installed the arcgis-js-api 4.x by using npm into my Angular application. After that when i'm going to deploy the changes in to my QA environment, it has more than 500 build files. Earlier it was only 19 build files.
Can anyone help me to reduce the files and tell me why this happened.
npm package - https://www.npmjs.com/package/arcgis-js-api
ts.file
import { Component, OnInit, ElementRef,Input,OnDestroy,ViewChild,} from '@angular/core';
import Map from "@arcgis/core/Map";
import config from '@arcgis/core/config';
import MapView from '@arcgis/core/views/MapView';
import FeatureLayer from '@arcgis/core/layers/FeatureLayer
    const map = new Map({
      basemap: 'topo-vector',
      layers: esriLayers
  const view = new MapView({
      container,
      map: map,
  this.view = view;
.html file
<!-- Map Div -->
<div #mapViewNode></div>
AndyGup
I'm a little confused - the comments above mention using https://www.npmjs.com/package/arcgis-js-api but the sample is using https://www.npmjs.com/package/@arcgis/core? Also, what were you using previously that only had 19 files on-disk, that sounds like you might have been using esri-loader which is CDN-based. Can you share a github repo?
Check out our Angular 13 sample: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-angular-cli. I'm seeing 208 files and 8.5MB on-disk. Note, not all of these files are being used on initial application load.
