Why does Dijit popup persist after mouse-over event?
783
09-25-2019 07:04 AM
JustinBridwell2
Occasional Contributor II
I have an application that needs a popup on a layer during mouse-over. I am trying to use the Dijit Popup
define(["dojo/_base/declare","esri/graphic","esri/layers/GraphicsLayer","esri/InfoTemplate",.."esri/lang","dojo/_base/url","dojo/_base/lang","dijit/TooltipDialog","dijit/popup","dojo/dom-style","dojo/domReady!" ],  function (declare, Graphic, GraphicsLayer, InfoTemplate, esriLang, Url, lang, TooltipDialog, dijitPopup, domStyle) {return declare([GraphicsLayer], {   ....
The popup does display during the listening event, but it never goes away when the user mouses over a new feature. I am trying to use the example from this demo, but something is not quite right. First here is the error I get:
Error: Tried to register widget with id==tooltipDialog but that id is already registered
And here is the code I am trying to apply in my app. Any suggestions on how to get this to work? ***Note: 'this.' is a GraphicLayer. Also, I am using api 3.29 (not the latest version - I am refactoring an old app).
....        dialog = new TooltipDialog({            id: "tooltipDialog",            style: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100"        });        dialog.startup();         this.on("mouse-over", function (evt) {            var content = esriLang.substitute(evt.graphic.attributes);            dialog.setContent(content);             domStyle.set(dialog.domNode, "opacity", 0.85);            dijitPopup.open({                popup: dialog,                x: evt.pageX,                y: evt.pageY             });            //this.setInfoTemplate(options.infoTemplate || new InfoTemplate("GeoJSON Data", "${*}"));            function closeDialog() {                map.graphics.clear();                dijitPopup.close(dialog);            }        });
RobertScheitlin__GISP
Justin,
   I don't see any mouse-out event that calls the closeDialog...
Justin,
JustinBridwell2
Doh! You're right Robert. I just added this after my "mouse-over" listener and it worked. Thanks!
this.on("mouse-out", function (evt) {
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
JustinBridwell2
OK, it seems like its been marked as correct. Thanks again.
