I have a map that contains features services, map services and graphic layers. What is the best way to select multiple features from multiple layers? For example, I want a user to be able to select a point in a mass of features from multiple layers and cycle through the features in a custom side panel to find the feature they are interested in.
I tried using hitTest, but that only returns the first feature from each layer. Too bad.
I found this example for 3.x. Would this be the best approach in 4.x as well? Any chance I could get one of your awesome working codepen examples using 4.x?
Query and QuertyTask are kind of pain because the buffer needs to change based on the zoom level. I know the API is already accounting for that using hitTest and other methods. Are there any other approaches we should consider? For example, in 3.x, we used var popup = map.infoWindow and connect.connect(popup, "onSetFeatures", function() {}) to trigger the custom panel based on a click on the map. Is there an equivalent approach in 4.x?
