WebMercator to Geographic and back gives a different point
724
12-03-2020 02:32 PM
AmarG1
New Contributor II
Using WebMercatorUtils to convert a point from webmercator to geographic and then back to webmercator doesn't give the original value back. Any ideas why?
point1: {x: -27763769.230105422, y: -6212655.210572942}
webMercatorUtils.webMercatorToGeographic() on point1 returns point2
point2: {x: 110.5938175582902, y: -48.63203914410154}
webMercatorUtils.geographicToWebMercator() on point2 returns point3
point3: {x: 12311247.455472855, y: -6212655.210572806}
I was hoping point1 and point3 to be same but that doesn't seem to be the case.
Thanks!
DanPatterson
MVP Esteemed Contributor
same datum for the geographic?  There are many GCS's
... sort of retired...
AmarG1
New Contributor II
Hi Dan,
I tried this instead:
point1 = {"spatialReference":{"wkid":3857},"x":-27763769.230105422,"y":-6212655.210572942}
let point2 = webMercatorUtils.project(point1, { wkid: 4326 });
point2 : {"spatialReference":{"wkid":4326},"x":110.5938175582902,"y":-48.63203914410154}
let point3 = webMercatorUtils.project(point2, { wkid: 3857 });
point3: {"spatialReference":{"latestWkid":3857,"wkid":102100},"x":12311247.455472855,"y":-6212655.210572806}
Does that address datum?
Thanks!
DanPatterson
That isn't due to a datum difference assuming your long/lat values are correct
You can confirm using an online calculator
AmarG1
New Contributor II
I'm getting the same response from https://tool-online.com/en/coordinate-converter.php#
-Thanks
DanPatterson
here are the images for various combinations from there.
so assuming this is correct... and you have checked your inputs
