view.goTo
2664
10-30-2019 04:51 AM
kawishabbas
Hi
View.goTo is not working any suggestion..?
  let point = {
                type: "point",
                x: i.geometry.x,
                y: i.geometry.y,
                spatialReference: { wkid: 32642}
   let  g = new Graphic({
                         geometry: point,
                         symbol: {
                                  type: "simple-marker",
                                  color: [227, 241, 18],
                                  outline: null
    view.goTo({
             target: point,
             zoom: 12
    view.graphics.add(g)
Output of point object is....
RobertScheitlin__GISP
Kawish,
   You have to project the geometry to the same spatial reference as the map.
Kawish,
  Though a Graphic can autocast the geometry object you are feeding it. The GoTo is expecting an actual Geometry class and not a Object class.
So you can change to:
view.goTo({
  target: g,
  zoom: 12
since the goTo function can take a graphic, geometry, etc
kawishabbas
Robert
Its not working properly and  map goes to wrong position while graphic update/add on exact location
Kawish,
kawishabbas
Thank You Robert
