Using the IdentifyTask with a WebMap from AGOL with the 4.x API
1084
6
05-04-2017 09:53 AM
TomFlahive
I have an ArcGIS Online WebMap with 5 web services on it and I would like to run an IdentifyTask so that I can obtain a list of all the features that fall under a clicked point.  I know that popups provide this same functionality of being able to identify all the features under a clicked point, but I am looking to present the data in a custom sidebar rather than a popup, so I figured using the IdentifyTask is the way to go.
A similar question has been asked and answered (by Kelly Hutchins) on how this might be done with the 3.x API (here), but I am trying to figure out how to do it with the 4.x API.
The part I am stuck on is what to pass in to the IdentifyTask in place of a service URL, as shown in the Esri example:
// Create identify task for the specified map service
identifyTask = new IdentifyTask(mapServiceURL);
Can the IdentifyTask be used with an AGOL WebMap, and if so, what needs to be done to accomplish that?
Thanks.
RobertScheitlin__GISP
Tom,
   That would be as simple as:
// get the first layer in the collection of operational layers in the WebMap
// when the resources in the MapView have loaded.
var featureLayer = webmap.layers.getItemAt(0);‍‍‍
identifyTask = new IdentifyTask(featureLayer.url);
Tom,
TomFlahive
Thanks Robert.  I didn't know it would just be a matter of pulling each individual URL.  I was thinking there would be a way to pass in all the layers from the WebMap at once.
So if I want to pull the data back for all 5 services on the WebMap, then I would just iterate through the layers and create a separate identify task for each one, correct?
Tom,
   The thing to look out for is the IdentifyTask is looking for the mapservice url and not an individual layer url (i.e. http //servername/arcgis/rest/services/servicename/MapServer vs http //servername/arcgis/rest/services/servicename/MapServer/1).
TomFlahive
What about the case where you have a WebMap that has web services that may come from different sources (from different servers), so one web service might have 3 individual layers, and another web service from a different source may have 2 individual layers, and so on.  In that situation would I need an IdentifyTask for each service?
Tom,
  Correct one for each service (not each service layer).
TomFlahive
Got it.  Thanks Robert!
