Using an external geocoder instead of ArcGIS World Geocoding Service
1206
01-13-2021 04:59 AM
AndresKasekamp
Is it possible to use the search widget with a different geocoder instead of the one suggested by Esri? I have an address search API, but I don't know whether is is supported?
Tags (3)
BlakeTerhune
MVP Regular Contributor
Yes. I think geocode services are configured like normal with the sources property.
Noah-Sager
Yes, the Search widget can work with the default Esri World Geocoder, with a layer, with a geocode service resource exposed by the ArcGIS Server REST API, or a properly configured 3rd party search API.
Search widget with a custom source (open data address search API for France)
https://developers.arcgis.com/javascript/latest/sample-code/widgets-search-customsource/index.html
Search widget with multiple sources (2 layers and Esri World Geocoder)
https://developers.arcgis.com/javascript/latest/sample-code/widgets-search-multiplesource/index.html
RyanBohan
Be sure to set the includedefaultsources to false
var searchWidget = new Search({
view: view,
allPlaceholder: "Search by street address",
autoSelect: true,
suggestionsEnabled: true,
includeDefaultSources: false,
sources: [
locator: new Locator({
//url: "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer" //World GeocodeServer
url: "your GeocodeServer"
name: "City Locator",
placeholder: "Street Address",
zoomScale: 1000
