Uncaught TypeError: Cannot read property 'spatialReference' of undefined
7091
12-24-2014 11:29 AM
MichaelSchnack
I'm creating a map that can be launched from a URL that contains a name, address and lat & lon.  When the maps launches I would like for it to automatically display an infoWindow containing the name & address at the coordinates that have been parsed from the URL.
I'm taking the coordinates and creating a new Point, then converting that point to web mercator and using it as the center of the map.  But when I try to convert the web mercator point to a screen point to use in map.infoWindow.show, I get the error: Uncaught TypeError: Cannot read property 'spatialReference' of undefined.
If I try to use the web mercator point in the show method the error is:  Uncaught TypeError: Cannot read property 'toScreen' of undefined.
Any suggestions would be appreciated, thanks.
require([
    "esri/map", "esri/geometry/Circle", "esri/symbols/SimpleFillSymbol", "esri/layers/GraphicsLayer", "esri/units", "esri/geometry/webMercatorUtils", "esri/geometry/Extent", "esri/layers/FeatureLayer", "esri/dijit/Geocoder", "esri/dijit/BasemapToggle", "esri/InfoTemplate", "esri/dijit/InfoWindow",  "esri/geometry/ScreenPoint", "esri/dijit/Measurement", "esri/symbol", "esri/graphic", "esri/symbols/Font", "esri/symbols/TextSymbol", "esri/Color", "esri/tasks/query", "esri/geometry/Point", "esri/SpatialReference", "esri/request", "esri/config", "dojo/dom", "dojo/on", "dojo/parser", "dijit/layout/BorderContainer", "dojo/domReady!"
], function(
    Map, Circle, SimpleFillSymbol, GraphicsLayer, Units, webMercatorUtils, Extent, FeatureLayer, Geocoder, BasemapToggle, InfoTemplate, InfoWindow, ScreenPoint,  Measurement, Symbol, Graphic, Font, TextSymbol, Color, Query, Point, SpatialReference, esriRequest, esriConfig, dom, on, parser
  parser.parse();
  var params = location.search.substr(location.search.indexOf("?")+1);
  params = params.split("&");
  var coname = params[0].substr(3).replace(/%20/g,' ');
  var addr = params[1].substr(5).replace(/%20/g,' ');
  var csz = params[2].substr(4).replace(/%20/g,' ');
  var lon = parseFloat(params[3].substr(4));
  var lat = parseFloat(params[4].substr(4));
  var addrPoint = new Point(lon,lat);
  var addrLocation = webMercatorUtils.geographicToWebMercator(addrPoint);
  console.log(coname);
  console.log(addr);
  console.log(csz);
  console.log(lon);
  console.log(lat);
  console.log(addrPoint);
  console.log(addrLocation);
    var map = new Map("map", {
        center: addrLocation,
        zoom: 17,
        basemap: "hybrid"
    var layerTaps = new FeatureLayer("http://172.30.5.86:6080/arcgis/rest/services/Serviceability/Serviceability_Taps/MapServer/0", {
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields: ["*"]
    var layerCoax = new FeatureLayer("http://172.30.5.86:6080/arcgis/rest/services/Serviceability/Serviceability_Coax/MapServer/0", {
        outFields: ["*"]
  var layerFiber = new FeatureLayer("http://172.30.5.86:6080/arcgis/rest/services/Serviceability/Serviceability_Fiber/MapServer/0", {
        outFields: ["*"]
  var layerInfoUSAbus = new FeatureLayer("http://172.30.5.86:6080/arcgis/rest/services/Addresses/InfoUSA_Bus/MapServer/0", {
        outFields: ["*"]
    map.addLayers([layerTaps, layerCoax, layerFiber, layerInfoUSAbus]);
  if(document.getElementById('taps').checked) {
  layerTaps.show();
  } else {
  layerTaps.hide();
  if(document.getElementById('coax').checked) {
  layerCoax.show();
  } else {
  layerCoax.hide();
  if(document.getElementById('fiber').checked) {
  layerFiber.show();
  } else {
  layerFiber.hide();
  if(document.getElementById('InfoUSAbus').checked) {
  layerInfoUSAbus.show();
  } else {
  layerInfoUSAbus.hide();
    on(dom.byId('coax'), 'change', CoaxLayerVisibility);
    function CoaxLayerVisibility() {
        if (layerCoax.visible) {
            layerCoax.hide();
        } else {
            layerCoax.show();
    on(dom.byId('taps'), 'change', TapsLayerVisibility);
    function TapsLayerVisibility() {
        if (layerTaps.visible) {
            layerTaps.hide();
        } else {
            layerTaps.show();
  on(dom.byId('fiber'), 'change', FiberLayerVisibility);
    function FiberLayerVisibility() {
        if (layerFiber.visible) {
            layerFiber.hide();
        } else {
            layerFiber.show();
  on(dom.byId('InfoUSAbus'), 'change', InfoUSAbusLayerVisibility);
    function InfoUSAbusLayerVisibility() {
        if (layerInfoUSAbus.visible) {
        } else {
  var toggle = new BasemapToggle({
        map: map,
        basemap: "streets"
    }, "BasemapToggle");
    toggle.startup();
    var measurement = new Measurement({
        map: map,
  defaultLengthUnit: esri.Units.FEET,
  defaultAreaUnit: esri.Units.SQUARE_FEET
    }, "measurement");
    measurement.startup();
  function measurementReset() {
  measurement.clearResult();
  measurement.setTool("distance", false);
  measurement.setTool("area", false);
  measurement.setTool("location", false);
  document.getElementById("resetButton").addEventListener("click", measurementReset);
  var screenPnt = map.toScreen(addrLocation);
  map.infoWindow.resize(300, 250);
  map.infoWindow.setTitle("InfoUSA Business Address");
  map.infoWindow.setContent("<b>Name</b>: " + coname + "<br><b>Address</b>: " + addr + "<br><b>City, State, Zip</b>: " + csz);
  map.infoWindow.show(screenPnt, map.getInfoWindowAnchor(screenPnt));
KenBuja
Could this be a timing issue? Try putting that code into the map's load event, so you know that it's ready for use.
map.on("load", function (){
KenBuja
MichaelSchnack
That was it.  Thank you!
