TypeScript error when creating Search Widget (JS 4.8)
1551
08-29-2018 05:00 PM
PhilLarkin1
Occasional Contributor III
I'm getting an error when assigning a source to a searchWidget. It appears I might be using incorrect syntax for TypeScript.
(TS) Type '{ locator: Locator; name: string; placeholder: string; }[]' is not assignable to type 'Collection<FeatureLayerSource | LocatorSource>'. Property 'add' is missing in type '{ locator: Locator; name: string; placeholder: string; }[]'.‍‍
import Locator = require("esri/tasks/Locator");
import Search = require("esri/widgets/Search");
var sources = [{
    locator: new Locator({ url: "https://gis.spokanecounty.org/arcgis/rest/services/Locators/AddrComposite/GeocodeServer" }),
    placeholder: "Search Addresses"
var searchWidget = new Search({
    view: view,
    includeDefaultSources: false
searchWidget.sources = sources;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Similar issue here: typescript files error on search widget
Definition file used: Small updates for version 4.8 (#27426) · DefinitelyTyped/DefinitelyTyped@0575e7d · GitHub
Tags (1)
MattDriscoll
Hey Phil, can you try this as a workaround for now?
const searchWidget = new Search({
            view: view,
          const sources = [
                url:
          type SearchSource = __esri.LocatorSource | __esri.FeatureLayerSource;
          searchWidget.sources.addMany(sources as SearchSource[]);
MattDriscoll
Hey Phil,
I believe it is because it is expecting a collection of a certain type and can't autocast the collection properly. Can you try just pushing to the existing sources since it should be empty on initialize?
    view: view,
searchWidget.sources.addMany([{
I'll talk to some colleagues and see if we can fix this.
-Matt
PhilLarkin1
Hi Matt Driscoll‌
Thanks for taking the time to respond. Looks like the collection is still not cast properly. I have attached the full error to my main post.
TS2345 (TS) Argument of type '{ locator: Locator; name: string; placeholder: string; }[]' is not assignable to parameter of type 'Collection<FeatureLayerSource | LocatorSource> | (FeatureLayerSource | LocatorSource)[]'.
MattDriscoll
            view: view,
          const sources = [
                url:
PhilLarkin1
That works.
I can't get results with a 10.3.1 server, but can with ESRI's World Geocoder (10.6.1). This is a different issue, though. (https://community.esri.com/thread/220696-search-widget-sends-incorrect-query-string-48-js-api )
Thanks for your help.
PhilLarkin1
This now works as advertised at 4.9.
var sources = [{
    locator: new Locator({ url: "https://<url>/AddrComposite/GeocodeServer" }),
    placeholder: "search addresses",
    singleLineFieldName: "SingleLine",
    view: view,
    includeDefaultSources: false,
    suggestionsEnabled: true,
    sources:sources
var searchExpand = new Expand({
    view: view,
    content: searchWidget
view.ui.add([
        component: searchExpand,
        position: "top-left",
        index: 1
