trying to SELCET DISTINCT with layer.queryFeatures(query);
763
01-02-2022 06:21 AM
eyalj
New Contributor II
I'm trying to do SELECT DISTINCT or do something equivalent with layer.queryFeatures(query);
what should the values of query should be?
Tags (3)
2 Solutions
Kishore
@eyalj - you can define the return distinct in the query object.
query = new Query();
query.where = "condition";
query.returnDistinctValues = true);
 Please refer to the API returnDistinctValues
Regards,
Kishore
Kishore
@eyalj  - we have known limitations for this:
  • For service-based queries, this parameter applies only if the supportsAdvancedQueries capability of the layer is true.
  • Make sure to set returnGeometry to false when returnDistinctValues is true. Otherwise, reliable results will not be returned.
Hope you are comply with these limitations.
Regards,
Kishore
Kishore
Regards,
Kishore
eyalj
New Contributor II
When i change returnDistinctValues to true it says that suddenly i dont have any values,
Kishore
Regards,
Kishore
