Touch screen doesn´t respond with Javascript API 3.25
5615
16
08-14-2018 10:45 AM
ViridianaGómez_Olivera
Hi!
I have a problem with an application that uses API 3.25, when we use it in a touch device (not mobile, only monitor computers) this doesn´t work with the pan or zoom using the fingers on the screen; this only occurs in Google Chrome. Previously, this worked fine and we don´t had any problem. We have another application that uses API 4.8 and this work fine. I have tried using:
map.enablePinchZoom;
And:
map = new Map("map",
center: [-95, 30],
zoom: 5,
basemap: "streets",
isPinchZoom: true
And this doesn´t work. This problem is related to Google Chrome? or is something related to the API? Could you help me please?
Thank you in advance.
Regards.
RussRoberts
Esri Notable Contributor
This is something we are looking into, I responded to a similar thread here
https://community.esri.com/thread/219624-touch-screen-doesn-t-respond-with-javascript-api-325
ChristianDebono
New Contributor II
We have the same issue with Javascript API 3.23. It was working fine and noticed this happened when the phone updated to the latest Android Version running Android Pie, using Google Chrome; other browsers work fine.
Any help about this issue please?
RussRoberts
We are also looking into this issue on Android 9 (Pie) and touch nav with 3.x JSAPI apps.
Thanks for reporting.
TaylorKeen
New Contributor II
Yes, this issue seems to have been introduced in 3.x ArcGIS for JavaScript apps after updating to Android 9.0...  Hopefully there is a fix soon!
ChristianDebono
New Contributor II
I can confirm that the issue has been fixed with the release of JavaScript API Version 3.26
by Anonymous User
Not applicable
Hello,
There is a bug (BUG-000116101 Unable to pan map in Google Chrome with ArcGIS API for JavaScript 3.x application.) logged and we are working on it.
Thanks
by Anonymous User
Not applicable
Hello,
Thanks
ChristianDebono
New Contributor II
Any update about the Android 9 Pie issue please?
RussRoberts
It has been fixed and will be coming in the 3.26 update which is coming soon.
https://community.esri.com/message/794158-re-problems-with-api-javascript-35-fro-arcgis-using-pan-an...
