Token generation from Federated Server and Portal
605
07-20-2021 02:10 AM
MANESK
In our organization we use a federated ArcGIS Server with Portal. I'm consuming a secured REST service URL in a JavaScript
This is my code
var tokenvalue = $.ajax({
                type: "POST",
                url: "https://[mydomain]/server/tokens/generateToken",
                data: {
                    username: username,
                    password: password,
                    client: "requestip",
                    expiration: '120',
                    f: "json"
                dataType: "json"
            if (tokenvalue) {
                tokenvalue
                    .success(function (response){
                        if (response.token) {
	          console.log(tokenvalue)
                            IdentityManager.registerToken({
                                server: "https://[mydoamin]/server/rest/services",
                                token: response.token
                            console.log(response.token);
                            var layerUrl = "https://[mydomain]/server/rest/services/Landuse/MapServer";
                            var layer = new MapImageLayer({
                                url: layerUrl
                            map.add(layer);
application. I'm able to generate the token for accessing the service in the JavaScript application only with the PSA (ArcGIS Server) account.
I tried to disable the PSA account and then tried with the credentials of portal administrator account for acquiring token for the secured URL, but i got no luck using that.
Is it only possible to acquire token from the federated server only using the PSA or is there any other way.
Also kindly suggest to acquire the token using Portal to access the secured REST URL and the steps involved in it.
Anyone to help !!!!
