Toggling Light/Dark theme programmatically API 4.x
1409
12-10-2021 07:50 AM
RichardMoussopo
The API provides two different css files for light and dark theme. I am trying to figure out a better way of switching theme on toggle button click. I've tried unloading the light css file then load the dark css file and I am not impressed with this approach. Does anybody out there ever tried this?
Thank you
ReneRubalcava
I don't know how you're updating it, but you can just update the href of the link tag.
let theme = "dark";
btn.addEventListener("click", () => {
    if (theme === "light") {
      sheet.href = "https://js.arcgis.com/4.22/esri/themes/dark/main.css";
      theme = "dark";
    } else if (theme === "dark") {
      sheet.href = "https://js.arcgis.com/4.22/esri/themes/light/main.css";
      theme = "light";
https://codepen.io/odoe/pen/qBPaPpR?editors=1000
ReneRubalcava
let theme = "dark";
      theme = "dark";
      theme = "light";
RichardMoussopo
Thank you Rene, I am using React but this did the trick. I really appreciated
René_Ténière
René,
How do you listen for changes to the theme? I have developed a widget and would like to listen for the theme changes for the internal CSS.
René T.
LindaCecilieKjeldsen
This seems to no longer function for the popup? It seems "something" happened around version 4.25..? It is possible to make the popup light if you import light stylesheet, and dark if you import dark. But if you switch in runtime, nothing happens in the popup.
