I am using the TOC and the Identify task to accomplish the goal of my info-template.
--Trying to get each layer have its own info template based on attributes of that layer. Since not all layers have the same fields Names and attributes.
You can set the template to ${*} to get the raw fieldnames and values.
InfoTemplate | API Reference | ArcGIS API for JavaScript
You can loop through the attributes of a feature/graphic to create something fancier on the fly:
createTemplate(g){ var template = ["<table>"]; for(var fieldName in g.attributes){ template.push("<tr>"); template.push("<th>"); template.push(fieldName); // add name template.push("</th>"); template.push("<td>"); template.push(g.attributes[fieldName]); // add value template.push("</td>"); template.push("</tr>"); } template.push("</table>"); return template.join(''); }
I will see how that works out. Thanks,
My initial hope was to use the ${*}. I have turned off the fields I do not want displayed before I publish out the service however the OBJECTID field always publishes out with the service no matter if it is turned on or off. In addition it always gives "layername= " I was hoping I would not have to create an infotemplate and set fields for every layer given I have many.
