Time-aware Cached (Tiled) Maps
1092
03-25-2011 08:51 AM
DanielYim
New Contributor II
My organization has a huge raster that we need to display to show change with time, but right now--even from our LAN--it's rendering pretty slowly without a preload. To help with the speed, we are trying caching, but once we change from a dynamic to a tiled map service, all the time-related images are gone.
I was wondering if anyone can share some code with using time-aware tiled maps.
Thanks
DavidHollema
New Contributor III
Is a time-aware cached (tiled) service even possible?  I'm curious about this too as we have a need for it.  I can find zero in ESRI help docs on this topic.  My assumption then is no, it's not possible.
Thanks
DavidHollema
New Contributor III
The simple answer is no, it's not possible. Based on ESRI tech support response,
"While you can cache a time-aware service, the time-aware functionality will be lost and the data will just display at one time interval. So essentially, it doesn't work....I've logged a documentation bug for this, since it is not explicitly stated anywhere..There is also an existing bug...It's an enhancement request to add a warning that tells you when you switch to a cached map service that you will lose time-aware functionality."
StephenLead
Regular Contributor III
This kind of makes sense, since the cache is just a bunch of images which are pre-compiled for fast drawing. I imagine that cached layers weren't designed with time-awareness in mind.
Not code, but an approach you could try - build a separate cache for each "node" on the time-line, and build a slider control which shows the relevant cache layer as the slider is moved along the timeline.
