SWAP Webmaps sample and widgets
580
07-25-2019 09:20 AM
AxelLévy
New Contributor III
Hello,
I try to reproduce a tabbed application but with the possibility to have widgets in the map. (The Story Map Mapseries is too limited).
This example is almost perfect for me: https://developers.arcgis.com/javascript/latest/sample-code/webmap-swap/index.html
But when I add widgets (Home Button for example), they only load  after clicking a tab.
Someone can help me ?
Here my code
* Create multiple WebMap instances
var webmaps = webmapids.map(function(webmapid) {
return new WebMap({
portalItem: {
// autocasts as new PortalItem()
* Initialize the View with the first WebMap
var view = new MapView({
map: webmaps[0],
container: "viewDiv"
var homeBtn = new Home({
view: view
var layerList = new LayerList({
view: view
document
.querySelector(".btns")
.addEventListener("click", function(event) {
* On a button click, change the map of the View
var id = event.target.getAttribute("data-id");
if (id) {
var webmap = webmaps[id];
view.map = webmap;
var nodes = document.querySelectorAll(".btn-switch");
for (var idx = 0; idx < nodes.length; idx++) {
var node = nodes[idx];
var mapIndex = node.getAttribute("data-id");
if (mapIndex === id) {
node.classList.add("active-map");
} else {
node.classList.remove("active-map");
view.ui.add(homeBtn, "top-left");
view.ui.add(layerList, "bottom-left");
Btw if we could switch between layers and not webmaps it would be even better!
thank you in advance
Tags (1)
KenBuja
MVP Esteemed Contributor
This code adds the home button.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Swap web maps in the same view - 4.12</title>
    <style>
      html,
      body {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
      #viewDiv {
        position: absolute;
        right: 0;
        left: 0;
        top: 60px;
        bottom: 0;
      .header {
        position: absolute;
        top: 0;
        width: 100%;
        height: 10%;
      .btns {
        margin: 0 auto;
        display: flex;
        flex-direction: row;
        justify-content: center;
        align-items: center;
        overflow: auto;
      .btn-switch {
        flex-grow: 4;
        background-color: rgba(34, 111, 14, 0.5);
        color: #fff;
        margin: 1px;
        width: 50%;
        padding: 20px;
        overflow: auto;
        text-align: center;
        cursor: pointer;
      .active-map {
        color: #fff;
        background-color: rgba(34, 111, 14, 1);
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.12/"></script>
    <script>
      require(["esri/views/MapView", "esri/WebMap", "esri/widgets/Home"], function(MapView, WebMap, Home) {
        var webmapids = [
          "ad5759bf407c4554b748356ebe1886e5",
          "71ba2a96c368452bb73d54eadbd59faa",
          "45ded9b3e0e145139cc433b503a8f5ab"
          return new WebMap({
            portalItem: {
          map: webmaps[0],
          view: view
        document
            if (id) {
              view.map = webmap;
                } else {
    </script>
  </head>
  <body>
    <section class="header esri-widget">
      <div class="btns">
        <div class="btn-switch active-map" data-id="0">Missing Migrants</div>
        <div class="btn-switch" data-id="1">Refugee Routes</div>
        <div class="btn-switch" data-id="2">Sea Arrivals</div>
      </div>
    </section>
    <div id="viewDiv" class="esri-widget"></div>
  </body>
</html>
KenBuja
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <style>
      html,
      body {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
      #viewDiv {
        position: absolute;
        right: 0;
        left: 0;
        top: 60px;
        bottom: 0;
      .header {
        position: absolute;
        top: 0;
        width: 100%;
        height: 10%;
      .btns {
        margin: 0 auto;
        display: flex;
        overflow: auto;
      .btn-switch {
        flex-grow: 4;
        color: #fff;
        margin: 1px;
        width: 50%;
        padding: 20px;
        overflow: auto;
        text-align: center;
        cursor: pointer;
      .active-map {
        color: #fff;
    </style>
    <link
      rel="stylesheet"
    <script>
        var webmapids = [
          return new WebMap({
            portalItem: {
          map: webmaps[0],
          view: view
        document
            if (id) {
              view.map = webmap;
                } else {
    </script>
  </head>
  <body>
      <div class="btns">
      </div>
    </section>
  </body>
</html>
AxelLévy
New Contributor III
OK thanks a lot ! I understand. I wrote the view.ui.add in the wrong place
