Styling sketchViewModel
2126
06-16-2021 06:10 AM
JGraca
Hi all,
API Version 4.18
My current situation for this code is no matter what i do following the documentation, the inside of my area polygon is always blue and i need it to be transparent. Also, the polygon needs to be dashed and the code builds full lines. Basically, the whole style does not change no matter what i write.
My code:
const sketchViewModel = new SketchViewModel({
  view: mapView,
  layer: layers.search,
  updateOnGraphicClick: true,
  defaultUpdateOptions: {
    enableRotation: false,
    toggleToolOnClick: false
  polygonSymbol: {
    type: "simple-fill",
    color: [0, 0, 0, 0.2],
    outline: {
      color: [255, 255, 255],
      width: 2
What i get:
I want something like this:
RobertScheitlin__GISP
@JGraca,
Here is your codepen code updated for that:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8" />
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.18/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.18/"></script>
  <script>
    require(["esri/views/MapView",
      "esri/WebMap",
      "esri/Graphic",
      "esri/layers/GraphicsLayer",
      "esri/widgets/Sketch/SketchViewModel",
      "esri/geometry/Polygon",
      "esri/geometry/SpatialReference",
      "esri/geometry/support/webMercatorUtils"
    ], function (MapView, WebMap, Graphic, GraphicsLayer, SketchViewModel, Polygon, SpatialReference, webMercatorUtils) {
      let sketchViewModel;
      var graphicsLayer = new GraphicsLayer();
      var webmap = new WebMap({
        basemap: 'satellite',
        layers: [graphicsLayer]
      var view = new MapView({
        map: webmap,
        container: "viewDiv",
        center: [-9.40019762581224, 39.33930907833357],
        zoom: 6
      setUpGraphicClickHandler();
      addGraphics();
        view: view,
        layer: graphicsLayer,
        polygonSymbol: {
          style: "none",
          outline: {
            style: "dash",
            color: [168,168,168,1],
            width: 2
      sketchViewModel.on(["update", "undo", "redo"], onGraphicUpdate);
      function onGraphicUpdate(event) {
        const graphic = event.graphics[0];
        if (
          event.toolEventInfo &&
          (event.toolEventInfo.type === "move-stop" ||
            event.toolEventInfo.type === "reshape-stop")
          sketchViewModel.complete();
        } else if (event.state === "cancel" || event.state === "complete") {
          sketchViewModel.update([graphic], {
            tool: "rectangle"
          const coordinate = webMercatorUtils.webMercatorToGeographic({graphic})
        sketchViewModel._internalGraphicsLayer.graphics.map(function(gra){
          if(gra.geometry.type === 'polygon'){
            gra.symbol.outline.color = [0,0,0,0];
          if(gra.geometry.type === 'point'){
            gra.symbol.outline.color = [168,168,168,1];
      function setUpGraphicClickHandler() {
        view.on("click", function (event) {
          if (sketchViewModel.state === "active") {
            return;
          view.hitTest(event).then(function (response) {
            var results = response.results;
            results.forEach(function (result) {
              if (
                result.graphic.layer === sketchViewModel.layer &&
                result.graphic.attributes &&
                result.graphic.attributes.newDevelopment
                sketchViewModel.update([result.graphic], {
                  tool: "rectangle"
      function addGraphics() {
        const newDevelopmentGraphic = new Graphic({
          geometry: webMercatorUtils.geographicToWebMercator(
            new Polygon({
              rings: [
                [-13.43218004768601, 43.353861447707416],
                [-13.43218004768601, 36.364593011258414],
                [2.497995733559755, 36.364593011258414],
                [2.497995733559755, 43.353861447707416],
              spatialReference: new SpatialReference({
                wkid: 3857
          symbol: {
            style: "none",
            outline: {
              style: "dash",
              width: 2
          attributes: {
            newDevelopment: "search area"
        graphicsLayer.add(newDevelopmentGraphic);
        setTimeout(function(){
          sketchViewModel.update([newDevelopmentGraphic],{
            tool: "transform",
        }, 500);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
@JGraca,
If you want the polygon fill to be transparent then you need to set the fill style and if want the outline to be dashed then you have to set the outline style.
  polygonSymbol: {
    style: "none",
    outline: {
      style: "dash",
      width: 2
JGraca
Hi, thanks @RobertScheitlin__GISP for the reply.
I have done what you suggested and it worked, but i would like to change the following:
- Remove the orange lines from the border;
- Change the boxes border colors to grey (the ones you draw on);
- Allow the polygon to be always resized;
On a different project, the background and the border still is with the blue colors.
On codepen it worked
@JGraca,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
      "esri/WebMap",
      "esri/Graphic",
        map: webmap,
        zoom: 6
      addGraphics();
        view: view,
        polygonSymbol: {
          style: "none",
          outline: {
            style: "dash",
            width: 2
        if (
            tool: "rectangle"
            return;
              if (
                  tool: "rectangle"
            new Polygon({
              rings: [
                wkid: 3857
          symbol: {
            style: "none",
            outline: {
              style: "dash",
              width: 2
          attributes: {
            tool: "transform",
        }, 500);
  </script>
</head>
<body>
</body>
</html>
