Stop flashing of graphic on mouse pointer hovering
907
07-12-2021 12:10 PM
victhomas
New Contributor III
Hello all,
Looking for ways to stop the flashing of color while inside of a feature when hover over it.  Mouse pointer over the feature, it changes color, but then if I move the  mouse pointer/cursor while still inside of the feature it flashes.  It looks like its restarting the change of the graphic color over and over again.  Is there to just persist the color when hovering over the feature without it flashing?  Thanks.
Below is the sample code.
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.20/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.20/"></script>
    <script>
		require(["esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer"], (Map, MapView, FeatureLayer) => {
			const markerSym = {
			  type: "simple",
			  symbol:{
				type: "simple-marker",
				style: "circle",
				color: [108, 199, 143],
				outline: {
				  color: "blue",
				  width: 1
			const brewLayer = new FeatureLayer({
			  url: "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/BreweriesCA/FeatureServer/0",
			  renderer: markerSym,
			  visible: true
			let map = new Map({
			  basemap: "topo-vector",
			  layers: brewLayer
			let view = new MapView({
			  container: "viewDiv",
			  map: map,
			  zoom: 8,
			  center: [-116.1118, 33.17233]
			view.when(() => {
				view.on("pointer-move", evt => {
					view.graphics.removeAll();
					view.hitTest(evt).then(response => {
						if (response.results.length > 0 ) {
							let graphic = response.results[0].graphic;
							graphic.symbol = {
								style: "circle",
								color: [25, 97, 73],
								outline:
								  color: "white",
								  width: 1
							view.graphics.add(graphic);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
RobertScheitlin__GISP
@victhomas  Here is the fix for that.
<html>
  <head>
    <meta
      name="viewport"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
    <script>
			const markerSym = {
			  type: "simple",
			  symbol:{
				style: "circle",
				outline: {
				  color: "blue",
				  width: 1
			  visible: true
			let map = new Map({
			  layers: brewLayer
			  map: map,
			  zoom: 8,
			view.when(() => {
        let lastFID = null;
              if(lastFID === response.results[0].graphic.attributes["FID"]){
                return;
							graphic.symbol = {
								style: "circle",
								outline:
								  color: "white",
								  width: 1
              lastFID = graphic.attributes["FID"];
    </script>
  </head>
  <body>
  </body>
</html>
<html>
  <head>
    <meta
      name="viewport"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
    <script>
			const markerSym = {
			  type: "simple",
			  symbol:{
				style: "circle",
				outline: {
				  color: "blue",
				  width: 1
			  visible: true
			let map = new Map({
			  layers: brewLayer
			  map: map,
			  zoom: 8,
			view.when(() => {
        let lastFID = null;
                return;
							graphic.symbol = {
								style: "circle",
								outline:
								  color: "white",
								  width: 1
    </script>
  </head>
  <body>
  </body>
</html>
victhomas
New Contributor III
Thank you Robert
