Show table on popup
946
10-31-2018 03:37 AM
irtizahussain
I want to show the data table on popup, like when i click on the map if there is any relation define on the given layer e.g relation between different layers, then i will show the popup with relative table.
imritanshu
you can do it by setting up "esri/dijit/PopupTemplate" to your layers. It by default shows all relative tables details as well.
Hope it will help you!!
irtizahussain
Where i can put this, in require? or something else
JaredPilbeam2
MVP Regular Contributor
Irtiza,
If you're using ArcGIS API for Javascript 4.9 have a look at this sample code.
Multiple popup elements | ArcGIS API for JavaScript 4.9
