Set Zoom in and Zoom Out on map
3380
6
04-13-2020 05:07 AM
rsharma
Occasional Contributor III
Hi i want to set zoom in and out button n bottom right corner horizontally to each other, i did trying it with css, but it do not work in responsive pages.
Any solution will be helpfull.
AnneFitz
Hi Rajni,
You can use the default zoom widget, but set the layout: "horizontal", and then add it to the bottom-right, like this:
var view = new MapView({
   container: "viewDiv",
   map: map,
   ui: {
      components: ["attribution"] // removes default widgets except for attribution
var zoom = new Zoom({
   view: view,
view.ui.add(zoom, "bottom-right");
AnneFitz
Hi Rajni,
   map: map,
   ui: {
   view: view,
rsharma
Its not working, do i need to add in require something, it even stops my recentre button to display. and no button is shown on map
          map: webmap,
          center: ['<?=$map_xy_coordinate['x']?>', '<?=$map_xy_coordinate['y']?>'],
          zoom: 15,
           ui: {
 view.when(function() {
          // Add the boundary polygon and new lot polygon graphics
          // create DOM object
          var recenterBtn = domConstruct.toDom("<div class='map-button esri-component esri-locate esri-widget--button esri-widget' role='button' title='Recenter'>RECENTRE<span aria-hidden='true' role='presentation'></span></div>");
                           view: view,
          // add to view
          view.ui.add(recenterBtn, "bottom-right");
RobertScheitlin__GISP
Rajni,
  Did you add the obvious one? "esri/widgets/Zoom"
rsharma
No
rsharma
Hi sir,
I tried the same and it still not working and blocked to display my other buttons also
Rajni,
  That means you have a error in how you added it to your requires array. I added it to my sample of your code without any issue.
