Using a WebScene, how do I enable the "See through ground" option?
The AGOL viewer and PRO viewer have this functionality, so I know it exists, just can't seem to find the right property to set.
Thanks
Solved! Go to Solution.
The property is basemapTerrain.opacity, change it from 1 to 0
The similar functionality is SceneView.basemapTerrain.wireframe, but the opacity property you mentioned is much more useful to me !
In 4.6, which object do I apply these property to? can't find either of the two in the reference.
It is the same code, in the require and function at the beginning of your script it is needed to add "esri/basemap" (even if yourself have not added any basemap in your local scene), then after the variable creating a "new SceneView" you add SceneViewVariableName.basemapTerrain.opacity = 0 as said above.
